Check hybrid system and code p261b
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GroovyMike, Jan 16, 2023.
  1. GroovyMike
    GroovyMike Junior Member
    I was driving and got this “check hybrid system” and lost powef. Pulled over and got the code P261B. Turned car off and set for a few mins and when I turned it back on the chech hybrid system was gone. I replaced the water pump but when I turn the car on now it says check hybrid system. I tried putting it in maintenance mode and can get the screen to say maintenance mode but then when I press the brake and start button it just turns off. This is a 2011 Prius with around 230,000 miles on it. Please help.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    need codes read
  3. GroovyMike
    The only code it gives me is P261B.
  4. tankyuong
    1,555
    662
    Central MO
    need a better code reader like techstream
