Gen 4 modules for Gen 2 pack
Discussion in 'Gen 2 Prius Technical Discussion' started by Freeport, Jan 25, 2023.
  1. Freeport
    Freeport Junior Member
    Seattle
    Currently have a 2008 Prius, looking to upgrade my pack with Gen 4 modules. On the lookout for low mileage Gen 4 packs to harvest the modules.
    Checking car-part com for salvage yard packs, and suggestions on testing the complete pack voltage. Attached pics of battery pack test points. I can test the Gen 2 pack but wanted to get proper test point for Gen 4.
    7.2 x 28 = 201.6 is target voltage for a healthy pack?
  2. PriusCamper
    PriusCamper Senior Member
    12,677
    5,117
    Pacific Northwest, USA
    In general the Gen2 Prius is compatible with Battery modules made for Prius between 2004-2015. That doesn't mean that you can't try to make a different shaped module in the 2016 Prius to the present work, we'd love to see how that goes.
    As for voltage reading of a healhty pack, that won't give you very much information about the pack, especially if it's been sitting for 6 months or longer because NiMH self-discharges so perfectly healthy modules that have been sitting for a long time could look worse to you than a pack that was recently pulled that has bad modules.
    Also are you trying to upgrade to Lithium? OR sticking with NiMH? That as well hasn't been done on here but we'd love to see how that goes.
    Main point is NiMH battery chemistry is 40 years old and inferior to other Lithium types, but Toyota sticks with NiMH because they have more of a monopoly/profitablity on that chemistry.
    If you want to upgrade the performance of your battery pack by every measure and use my affiliate link I can give you unlimited tech support and a discount on the install here: https://projectlithium.com/?ref=9qLPw There's a payment plan via Shopify if you don't want to pay for it all at once too.
    I live an hour south of Seattle and would be happy to answer your questions / help you with this project. I also an am authorized installer and warranty handler for Project Lithium as well.
  3. Albert Barbuto
    105
    97
    Northeast USA
    September 2020 I replaced the pack with Gen 4 modules from a 2019 wreck. The only difference I could see was that the vent tube assembly in the middle of each module is no longer used. Everything has been working perfect. :)
    Rocinante, Todd Bonzalez and Tombukt2 like this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    The Gen 4 NiMH modules are 100% interchangeable with the Gen 2 and Gen 3 modules. I've built many Gen 2 batteries using Gen 4 modules. The current Toyota replacement packs for Gen 2 and Gen 3 are built using the Gen 4 NiMH modules. There's no issue there.
    I had 2 brand new, off the shelf Toyota Gen 2 batteries that had sat on a shelf at a dealer for over a year and a half and were still perfectly fine. Self discharge issues don't become evident until a pack is a bit older, so if possible, get as new as possible. I would suspect anything 2018 and better would be perfectly fine. 2020 and newer would be better. There's plenty out there and don't forget the Corolla has the same modules, along with several others. Just make sure it's the NiMH option, not the lithium. But that would be very obvious when looking at it.
    NiMH in the Prius is tried and true. Most original batteries lasted much longer than the ten year warranties. Rebuild it with a recent Gen 4 donor and you're looking at another 8-10 years or more of proven reliability. I just did a battery swap with a member for their 2004. It had a rebuilt /replacement battery that was installed in 2017. All 28 modules in the battery were the same date code 14YI (Nov 14, 2007) and serial sequence so was most likely straight from a 2007 donor. That battery was over 15 years old before 1 module failed.
    If you're comfortable doing a bit of DIY, you can do a gen 4 upgrade and have the car another 10 years for around $1000, if you take the time to find a good donor. If you just want it back in service quick, there's literally hundreds of Gen 4 batteries available in the $500-$900 range or the aftermarket kits in the $1800-2300 range.
    I would not consider 202 volts as my goal for a healthy pack. A good Gen 4 should be able to hold 7.5 volts per module, or more, for over a year, easily.
    Rocinante and alftoy like this.
  5. Tombukt2
    12,900
    2,315
    As long as all the modules are good it doesn't matter what they are it's the 211 volt-based system all the modules electrically are the same The vent tube went away in 2010 I think I have non-vented rack of modules in my 2009 because when I bought my new battery I don't know 10-12 months ago they're not longer making the vented cells. So I threw my vent tubes out or they're laying in the shop on the floor or something and they're not needed just like if you put a sealed or a LifePo 12 volt in you can get rid of the vent tube for that.
  6. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    All the Gen 3 modules are still vented and have the relief valve. Somewhere around 2012 they stopped installing the rubber vent tubes that connected all the module reliefs. Starting with the Gen 4 modules, the relief valve was deleted from the module. The plastic tube is still molded as part of the module case, but there is no relief valve at the bottom of it, just a solid plastic floor.
    ColoradoCrow likes this.
  7. Tombukt2
    12,900
    2,315
    Well in the battery that I just bought for my '09 I think I have a picture of it before I stuck it in there are no vent tubes so I just have a rack and the bottom and top cover no front end and all that All the wiring is there and all I do is add the front end and close it up and I had no place to put the nipples aren't there on this rack to put my vent tubes on so they're laying on the floor in the shop still the rubber and plastic pieces so I don't know how that happened or what's up but very good so then I have late model sales in my old Gen 2 from the dealer like what 13 months ago or something now maybe a little less so I'm happy I guess
  8. Freeport
    Seattle
    Thanks for the replies. Looking to budget $1000 or so for a Gen4 pack. Noticed the Project lithium packs for $2000 but maybe out of my range for now. 2020 Corolla pack would be awesome.
  9. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    So you purchased a brand new Gen 2 Toyota replacement pack and it didn't have the rubber tubes installed? I bet it didn't have the black plastic piece that mounts on the white end plate nearest the ecu either. Probably had the safety disconnect cable in a separate plastic bag also, and you had to install that after swapping the electronics section to the new battery?
    I think everyone realizes you need to swap the electronics section from the old battery to the new one. The vent tube is no big deal whether you swapped the old one over to the new one or not, especially if yours has Gen 4 modules (but it's typically part of doing the job correctly to keep the car OEM). (I have never seen any Gen 1, 2, 3 or 4 modules that don't have the vent nipples molded into the plastic case. That would be something new. Any photos? Wonder if they're modules from a different application?) The black plastic piece that sits on top of the end plate? That's a big deal. Hope you swapped that over. That's the piece that ensures you get good cooling air flow through the modules, since it prevents the air from just blowing across the top of the modules and out the electronics section.
    Tombukt2 likes this.
  10. Tombukt2
    12,900
    2,315
    Yeah neither have I Not that I spend a lot of time looking at replacement batteries at the Toyota dealer that they don't generally have in stock but there was no separate bags the separate bags house the wiring to put the new front end or the old front end on the new battery the side wiring harness or whatever you call it there were no tubes The tubes I took off were in perfect condition with the plastic thingy and all that they're still laying right here there are no titties or nipples sticking out of the top of the silly modules like the battery I removed which at the time I was like big effing deal one less thing to be dealing with considering the modules are the same in the 211 volt systems which are whatever year to whatever year I imagine as the older batteries got used up by Toyota. The new racks just came down the pipeline with the little titties missing? That would be my guess and Toyota figure they didn't need to make a TSB about it or eight and a half by 11 paper explaining anything I guess they just gathered people would be smart enough that when those pieces don't have a place to go more than likely the reason would be is because they're like the new batteries that don't have them at least the person that works for Toyota or in the shop would gather this out in the field I don't know maybe people call the parts department and then they tell them oh if it doesn't go on there and it doesn't have a place to sit throw them off to the side you don't need them everything will work fine. I don't know this is how my rack N case came. I accepted it installed it and been running the h a l e out of it
  11. Freeport
    Seattle
    Was able to locate a 2017 Prius HV Battery, car mileage was supposedly 38,000 miles, $950. Wasn't able to verify the voltage where it sat. Got it home and had to figure out how to test it without jolting myself. Finally test showed 230 volts after sitting for a year, so that was a relief. Quite sure that orange safety plug or circuit breaker does not break the circuit. I unplugged every cable on the left hand side of the pack in yellow rectangle, and measured voltage at the blue arrows.
    Started moving the modules to a spare Gen 2 pack that I acquired for $200. The Gen 2 ecu had a whisper of green corrosion in the connectors, cleaned the corrosion on the cable plug and the ecu connector. Traces of corrosion on Gen2 frame wire, a vinegar bath and grey scuff pad cleaned the bus bars. Using the larger diameter bus bar nuts from the Gen 4 pack which had light corrosion.
    Not sure how long the pack sat in the car in the salvage yard, but had a stash of sunflower seeds, dog food, cat food, squirrel or mice? Glad whatever it was didn't pee on the pack modules.
  12. dolj
    dolj Senior Member
    8,423
    4,284
    Wellington, New Zealand
    I would not bother trying to clean up the corroded frame wire, just order a new one and replace it. They're only about $80 from an online dealer parts store. I'd probably source a used battery ECU if any of the pins had corrosion and just replace that too. I don't really care for having ongoing problems, but that's just me.
    Freeport likes this.
  13. Tombukt2
    12,900
    2,315
    Just make sure you put some corrosion inhibitor on any thing that was starting to corrode that you cleaned up put something on that cleaned up area or areas so that it doesn't start again or start so quickly again or whatever butter it up with something that will flow the juice and keep the corrosion at bay and you should be good to go for a while reasonably good find and the plug does shut off the full voltage going to the relays and that's what that's for. It has a big 125 or 150 amp fuse in it.
    alftoy likes this.
  14. dolj
    dolj Senior Member
    8,423
    4,284
    @Freeport is correct in that the safety interlock does not make the battery itself safe, it merely splits the battery into two ~101 V batteries. It is not until the bus bars are removed from at least one side that the voltages become safe to work with.
  15. James Analytic
    329
    51
    Michigan
    Was wondering in regards to a faster module swap from a known working Gen 4 HV pack, if the whole compressed module assembly would be quicker to move over into the Gen 2 case if done carefully or if the load could damage modules if buckles or something? Was thinking only might need to remove all the wires, lower bolts holding the modules and the end compression bar brackets nuts. Then just move all the modules compressed at one time?
    Either way, decided to see about interchange and I read that the end compression bracket from the 2007 to 2011 Camry might also interchange.
    Appears BRACKET 74401-47020 is for the 2004-2009 and possibly Camry part number, though no Toyota related site seems to have vehicle fitment info. A couple eBay sellers show as interchange.
    There is info for the 2010-2017 Toyota part # G92J5-47020, replaces G92J5-47010.
    Battmech site notes for that for the 2004-2015 TOYOTA PRIUS COMPRESSION BLOCK WITH BOLTS (28) part, compatible with:
    Toyota Prius Gen II 2004-2009
    Toyota Prius Gen III 2010-2015
    Toyota Prius Gen IV 2016-2022
    Lexus CT200H 2010-2015
    Update: Looks like I can still edit this post. Long story short, interchange doesn't look feasible to be equivalent without some hacks. The Gen 4 compression end parts each have a plastic peg on one side at the base that goes through a hole in the case on the rear facing side found assembled as. No four rivet bolts in those hole locations as in the Gen 2 case design obviously. So, appears makes more sense that the older brackets are forward compatible in theory if one uses a bolt and nut in place of the plastic plug in a hole on each side. Albeit, the issue that will arise will be mounting the HV Battery ECU and some new found part that I am guessing is a fuse that is mounted in that location instead of the safety orange quick connect. Furthermore, I am not certain the upper and lower outline profiles are the same for the airflow blocking parts to mate equivalently either way backward or forward compatible interchange as a compressed block say if only cutting off the plastic pegs of the Gen 4 design so to be able to seat on the rivet bolts on the Gen 2 design case. I'll try to update with video or photo later.
    #15 James Analytic, Sep 18, 2025
  16. PriusCamper
    12,677
    5,117
    I'm fairly certain the modules themselves are the only thing that are going to be compatible with Gen2 and the rack won't be, or at least will require modifications.
    James Analytic likes this.
  17. James Analytic
    329
    51
    Michigan
    Not quite complete assessing, though somewhat still seems like the Gen 4 compressed module rack possibly will fit in the Gen 2 case if the end brackets pegs are cut off. Not certain if the end bracket base hole location was designed yet to fit on the Gen 2 rivet bolts and not certain if the plastic airflow blocking parts on the controls side and the opposite intake and exhaust vent ducts will fit.
    Update: Gen 4 potential rivet bolt location are approx little over a half inch narrower than the more like 11 inch spacing of the Gen 2. Also, appears the Gen 4 case is heavier duty thicker steel compared to the weaker more flimsy Gen 2. Guessing takes more load than maybe was prior loaded onto the Gen 2 compressed pack? Appears the HV pack is better secured in the Gen 4 as well. Wondering if physical loading cumulative stress was identified that was adverse to the Gen 2 design? Still seems like can be made to fit with the end bracket pegs cut off and maybe some additional foam to block the controls end, though wouldn't be advised as the base of the ends brackets doesn't seem as secure so nor would the compressed 28 modules pack be.
    Interestingly, the single side adhesive foam is directly adhered on the entire front and back length of the modules in the Gen 4 design and not on the case cover-lid like on the Gen 2.
    #17 James Analytic, Sep 18, 2025
  18. Tombukt2
    12,900
    2,315
    I'm assuming similar to Gen 3 case
  19. James Analytic
    329
    51
    Michigan
    Gen 3 is closer to Gen 2 case in regards to compression bars with bolts and end brackets from what I have. Does look like the Gen 3 bolts for the compression bars are closer to the Gen 4 if not the same. Gen 4 end brackets are not interchangeable IMO being not as secure footed.
    Wound up finding out today after posting above, that I was given a HV battery pack reported as bad and with almost entirely bad modules where three are isolation faults modules. Anyway, that pack had a Gen 3 end bracket that is almost identical in size spec seemingly to the Gen 2 other than an eye for the temperature sensors wire(s) to go through on the top controls side.
    I read resistances of the thermistors as well and Gen 4 are lower in value by maybe 2Kohms. So if the 9-11kohms Gen 2's are considered maybe 10Kohm ones, I'd guess the Gen 4 are 8kohm ones or are something different or maybe I never noticed they may be Negative Temperature Coefficient (NTC) thermistors being possibly the Gen 4 resistors were outside in the warmer temp longer throughout the day?
    I had a few thoughts on how could one integrate the better Gen 4 pack in general paired switched or alone solely since seems way more rugged. Seems like can make a conversion adapter for the block sense wires to use the Gen 2 HV battery ECU instead of the Gen 4 HV battery ECU, though wasn't certain about the thermistors temp resistance curve and current clamp electrical specs. Similarly wondering what the specs are for the contactors-relays and precharge resistor. Didn't get that far yet to determine if feasible where adapters alone might be a way.
    #19 James Analytic, Sep 18, 2025
  20. PriusCamper
    12,677
    5,117
    The lighter metal case for the Gen2 is possible because they use a huge number of bolts to secure it in place. In Gen3 and Gen4 they use less bolts and a more rigid case design to compensate for less bolts.
    As for modifying Gen4 end caps on racks, I've done something similar to make Gen3 end caps fit into a Gen2 pack.
