In November, 700 Intercontinental Weapons Were Launched Against the USA?
Discussion in 'Fred's House of Pancakes' started by ETC(SS), Feb 3, 2023.
  1. ETC(SS)
    6,903
    Who is acting, and who is reacting?
    51,012
    Does it matter?
  3. bwilson4web
    15,982
    It sounds like a US weather balloon that failed to ‘pop’ as it reached peak altitude. Very cold air might have limited it’s climb and/or defective balloon with too strong envelope.
  4. bisco
    51,012
    Would it be that hard for the military to recognize that?
  5. bwilson4web
    15,982
    Given the 40,000 ft altitude risk to commercial aviation, it was target practice.
  6. tochatihu
    tochatihu Senior Member
    9,507
    3,669
    Kunming Yunnan China
    2001 Prius
    The weather balloon launcher would detect Bob's scenario, if they received enough radio-ed data. They might inform military directly. Or, mil might ask all launchers if they had bad flight profiles. Don't know how those communication chaains work.
    Radiosonde Observation
  7. Leadfoot J. McCoalroller
    7,825
    7,292
    Pennsylvania
    2018 Prius c
    Now a third thingy.
    And I notice that they seem to be going out of their way to use older F-22s to do the deed, despite the fact that F-35s were based closer in at least 2/3 cases. I guess they don't want to show off the new stuff yet.
  8. tochatihu
    9,507
    3,669
    2001 Prius
    F-22 has a higher (stated) service ceiling. That may not matter if both can launch whatever firestick is chosen.
    I suspect that pilot or base commander seniority figures into who gets to go. Ya gets to shoot and target does not shoot back. Fun and maybe ya gets to put a balloon image below cockpit window.
  9. tochatihu
    9,507
    3,669
    2001 Prius
  10. bisco
    51,012
  11. bwilson4web
    15,982
    Shara Palin must be jealous.
  12. bisco
    51,012
    she probably took a few shoots herself
  13. tochatihu
    9,507
    3,669
    2001 Prius
    Once again y'all made me look. There are rifle bullets that can reach 10,000 feet. Maybe something off the charts could get to 15,000? But oh my dears, higher is not in reach.
    Let us suppose that Alaska National Guard has something stronger (say, with 10 kg of propellant), and might gift a unit to an ex-Governor. Shoot! I expect her to miss. Target acquisition and guidance are things.
    As readers will have noticed, all efforts to pop these balloons have used more sophisticated approaches and spent $millions. That works. Ground-level gunning is play.
  14. bisco
    51,012
    a giant needle would do it
    CR94 likes this.
  15. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    ... or a 22LR at close range.
  16. Leadfoot J. McCoalroller
    7,825
    7,292
    Pennsylvania
    2018 Prius c
    While I don't doubt needles and garden guns, I've read elsewhere that they've been using anti-aircraft missiles with proximity-fused warheads in the hopes of knocking out the targets' power systems suddenly to improve the chances of data recovery later.
  17. bisco
    51,012
    why can't we just snag these things and drag them down?
  18. Leadfoot J. McCoalroller
    7,825
    7,292
    Pennsylvania
    2018 Prius c
    You first.
    We don't know what's in it. Could include explosives to self-destruct sensitive parts to prevent us from reverse-engineering.
    We do that too- heck, we did do that on the EP-3 they forced down 20 years ago. The difference in that situation was that it was a manned plane, and the crew on board used some self-destruct devices to wreck the most sensitive stuff before they were obliged to disembark.
    With a robot, there's still every chance of a self-destruct, but no operator nearby to judge if using it might make things worse by injuring someone.
    So they're using explosives to "shock" the things, trying to cause electrical power and computer controls to stop instantly in the hopes of preserving everything else in-state for analysis- including any self-destructs.
  19. bisco
    51,012
    but they're just weather balloons
  20. Leadfoot J. McCoalroller
    7,825
    7,292
    Pennsylvania
    2018 Prius c
