12V Battery Cable help ASAP
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priuspubescent, Nov 16, 2020.
  1. rjparker
    10,365
    6,488
    If the battery and cable are your only issues you are very lucky. 2.5v means it was discharging for many weeks or it quickly discharged into a dead short that somehow bypassed the fuse in the terminal. A lot of this is pretty basic. Get some help even if its an experienced diyer with a meter.
  2. Likeawind
    Likeawind Member
    109
    Houston
    Ordered the fuse box off ebay for $15, looking for the cable now. Will buy the splicer from home depot.
    If anyone has this cable please let me know. Thanks
  3. Likeawind
    Likeawind Member
    109
    Houston
    I'm going to attempt to do this myself, bit of a learning curve but with your guidance I can achieve a positive outcome.
    SFO likes this.
  4. Likeawind
    Likeawind Member
    109
    Houston
    Autozone said battery is toasted, its only four months old. He showed me failed and at zero volt.
    Now I’m thinking car is not dead because of burnt fusebox and may be it was burnt all along and I never noticed it. Regardless I have already cut the cable and will head to the junkyard.
    ColoradoCrow and SFO like this.
  5. Likeawind
    Likeawind Member
    109
    Houston
  6. Likeawind
    Likeawind Member
    109
    Houston
    Got the wiring harness and battery, waiting for the fuse box to arrive
  7. Likeawind
    Likeawind Member
    109
    Houston
    Update! I finally got the car up and running, found out the negative battery terminal is way bigger than the battery post, seems like I have no luck with this car as I parked the car after a test drive my MFD & clock went dark :( I wonder sometimes now what did I do to deserve this:(
    Does anyone know where can I source a narrow negative battery terminal from?
    MFD & Clock - Did I blow a fuse because chances of burning out both of them at the same time is pretty slim. Should I look for the fuse under the hood and beneath the steering wheel, please advise. Thanks
  8. Stevewoods
    Stevewoods Senior Member
    663
    1,187
    Seattle, WA
    If the post from the battery is too "skinny" so the clamp is too loose, auto parts store sell lead shim caps that slip down over the post. Bought a pack from NAPA in December. Only a few bucks. Part NW 740255. If the shim is too bulky, cut in half vertically where the side cutouts are and just use half a shim.
    #48 Stevewoods, Mar 1, 2023
  9. Likeawind
    Likeawind Member
    109
    Houston
    Thanks, did you have to modify it being broad in the bottom? or does it slip over nicely?
  10. rjparker
    10,365
    6,488
    How did you end up with the wrong negative cable? I do have one that I might sell for $20 plus shipping.
    82123-47040 toyota
    Link
    #50 rjparker, Mar 1, 2023
  11. Stevewoods
    663
    1,187
    Seattle, WA
    It slipped over the post fine, but it was a smidge too thick using the entire shim, which is why I cut it in half -- lengthwise, not horizonally. Then it was fine.
  12. Likeawind
    Likeawind Member
    109
    Houston
    is it very thick, can I use a wire cuter?
  13. rjparker
    10,365
    6,488
    You do have to be cautious about leaving a gap between the terminal clamp and the post. As much as 80-100 amps can flow through the negative cable. Burning and melting are caused by marginal connections carrying high current.
    Did you burn your original negative cable as well?
  14. Stevewoods
    663
    1,187
    Seattle, WA
    I doubt you will have to cut it. From what I gather most people have no trouble with the shims. I was just using a mini hacksaw. The shims are soft lead. But yeah, shims or no shims you always want snug clamps
  15. Likeawind
    Likeawind Member
    109
    Houston
    No negative is good but last owner was running a bigger battery hence the reason why it has bigger connectors. I bought the slim battery and now connector doesn’t fit on the terminal. I’m not driving the car until I fix this issue. Btw found out the MFD fuse is burnt so going to replace it.
  16. Likeawind
    Likeawind Member
    109
    Houston
    Bought a pack of battery shims from Autozone, lets see how it works out.
    Stevewoods likes this.
  17. Likeawind
    Likeawind Member
    109
    Houston
    I got the car ready and drove it around the neighbourhood and guess what I got the red triangle pop again :( arghhhhh I’m tired of this nuisance. I could barley reached home with loss of power. I called hometown hybrids and booked the appointment for Wednesday to replace the hv battery. Seems like I’ve no luck with this junk, talk about Toyota reliability, I’ll never buy another hybrid again.
  18. bisco
    52,198
    can't say that i blame you
  19. rjparker
    10,365
    6,488
    What was the hybrid battery charge level while you were driving it?
