Help I'm so screwed
Discussion in 'Gen 3 Prius Main Forum' started by SanGregprius, Feb 20, 2023.
  1. Mendel Leisk
    40,467
    Good you found it. How about a coat hanger wire with a slight hook bend at the end: if you get it to go through the tube and hook on at the far end.
    mikey_t likes this.
  2. nicoj36
    nicoj36 Active Member
    518
    162
    Worst case scenario if you still cant get it out. Maybe you can melt it with a blowtorch through the tranny and drain it out in liquid form.
  3. Mendel Leisk
    40,467
    ^ I don't think you want to do that...
    Mr. F, mikey_t and Johnny Cakes like this.
  4. SanGregprius
    SanGregprius Junior Member
    42
    17
    san gregorio ca
    ended up getting it out with a coat hanger. Thanks for the tips, everyone. the Endoscope was priceless.
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,037
    773
    Virginia, USA
    Awesome!! Was the solution Mendel Leisk's idea to go through it and hook it?
  6. SanGregprius
    42
    17
    san gregorio ca
    I bent a coat hanger tip to make a hook to fit inside the hose. Then was able to lift it vertically and take it out of the drain plug. I actually had a dream about pulling it out this was causing me such anxiety lol.
    CR94 and ASRDogman like this.
  7. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    737
    Monument, Colorado USA
    Phew, glad that had a happy ending and a good lesson for us all! I have a little endoscope I got years ago for doing plumbing work, never thought about it having an automotive use as well!!
    I'm getting ready to change the spark plugs in my daughter's old 2012 Sienna and seeing SO many warning about the little plastic clips on the plugs breaking when you remove them (plastic becomes brittle from the heat) so I've ordered 6 new cl ones just to have replacements in case some of them do break. (But I've learned to lift up on the tab with a small screwdriver or pick, never push down the other end, which makes breaking it much more likely.)
    SanGregprius likes this.
  8. xliderider
    xliderider Senior Member
    8,032
    3,211
    Honolulu, HI
    So, next time you change the transmission fluid, wrap a piece of tape or wire around the tubing outside of the fill hole, make a flag with the end such that it won't be possible for the tube to fall in.
  9. Johnny Cakes
    1,037
    773
    Virginia, USA
    So to summarize, you Mendel Leisked it.
  10. Leadfoot J. McCoalroller
    7,828
    7,294
    Pennsylvania
    2018 Prius c
    I wouldn't be surprised if he hires two dogs and an armed guard to watch over it next time. :ROFLMAO:
  11. Mendel Leisk
    40,467
    Measure the ID of the fill hole, note it, and before next time score a complete funnel extension hose with slightly smaller OD.
    FWIW, with 3rd gen hose OD of 5/8” (16 mm) is about the max.
    CR94 likes this.
  12. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    ^ A much better plan
  13. SanGregprius
    42
    17
    san gregorio ca
    Ended up buying a long hose that fits (1/2")
    I live about 40min away from the nearest parts store and sometimes not going into town to get the right part isn't the best idea. Especially trying to work between rain storms.:confused:
    Been working on my own cars about 20 years now and it's funny the lessons you learn over and over again. Rushing can defiantly get me.
