Prius 2004 230k miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rosnaldo Venega, Mar 7, 2023.
  1. Rosnaldo Venega
    Rosnaldo Venega New Member
    Massachusetts
    I use my Prius for deliveries, I drive about 6 hours and 90 miles a day.
    When I start in the morning, it is working perfectly and continues like this until I complete two and a half hours of work, it has been like this for two weeks.
    When I complete about two hours of work, the red triangle and the exclamation point appear on the dashboard, but the car continues to drive normally.
    After about four and a half hours, the combustion engine does not turn off when the car is stopped and the car starts to lose power when it comes to moving. Fuel consumption, which was high, starts to drop below 30mpg and the car seems to be making more effort to drive.
    The next day in the morning, I reset the error and the car runs normally, until all this happens again.
    I replaced the inverter pump and control valve, I also replaced the electric battery fan.
    There is no check engine, there is no code just the red triangle and the exclamation point.
    Fuel consumption is very good, 45-50 mpg but after four hours the hybrid won't run anymore.
    The problem is the hybrid battery? because it works normal for both of them until the problem occurs after hours of operation.
  2. Rosnaldo Venega
    Massachusetts
  3. JC91006
    JC91006 Senior Member
    16,766
    8,563
    You should read the codes, not just reset it. It'll usually point you to the direction of the problem. If you were to guess, maybe it's heat related and you need to check all your fluid levels
  4. bisco
    51,880
    Yes, it’s the hybrid battery. If you have the triangle and no code, you have the wrong reader.
    Get tech stream or similar and you will get codes and sub codes.
    You’ll have to open the battery and look for corrosion and clogging anyway
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,038
    1,966
    NJ-USA
    I would expect there to be something wrong with the hybrid drive system, the symptoms point to a weak battery.
    You need a more capable scantool to check all the systems on your car for codes.
    You can read this thread that reviews several scantool apps and devices.
    https://priuschat.com/index.php?posts/3290690
  6. Tideland Prius
    16,553
    *Threads merged*
  7. Rosnaldo Venega
    Massachusetts
    found out the problem, there is a blue rele near the fan and it was damaged, after changing it, everything went back to normal.
  8. bisco
    51,880
    congrats! those rele's are fragile
