Transmission Service
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by woodrow bryan, Mar 17, 2023.
  1. woodrow bryan
    woodrow bryan Junior Member
    New to me 2015 with 147K. ATF never changed. I tried to do it but the drain plug and fill plug are not coming out. Found out nobody wants to work on a Prius locally. Did find a garage that after checking the procedure and ensuring it was a straight dump and fill, agreed to put it on a lift and get the plugs out for me and do the fill. Was not crazy about going to Toyota for that.
    mikey_t likes this.
  2. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Was that successful? It's not difficult, once you get the car raised and reasonably level.
  3. Mendel Leisk
    40,457
    Are they using Toyota ATF WS fluid?
    regarding removal of fill and drain bolts, it helps to use a long handled (18”~ or so) ratchet wrench, with a 10 mm hex bit socket. A torque wrench for the install would need that socket too.
    One of the links in my signature is about transaxle fluid change. If you’re viewing on a phone, turn it landscape to see signatures.
    mypriuscious likes this.
  4. woodrow bryan
    They have it scheduled for next Thursday. Busy place and they work on my other vehicles so I really trust them. Doing me a favor actually as they normally never touch hybrids.
  5. Tombukt2
    11,995
    2,119
    Breaker bar 20 inch Mac for me . Barely half a pull and creak.
    woodrow bryan and Mendel Leisk like this.
  6. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    It is a straight dump and fill. The car should be level though. You should measure how much comes out and then put that amount back in. Generally 3.5qts I think.
  7. Mendel Leisk
    40,457
    The car being level during the fill is a dead-simple way to get the level right when filling: when it starts overflowing, it’s right. More info in aforementioned signature.
  8. woodrow bryan
    Scheduled for this coming week.
