Did I kill my beloved 05’?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gino Veltri, Mar 22, 2023.
  1. Gino Veltri
    Gino Veltri Member
    413
    40
    So I broke too hard to avoid rear ending someone on the highway and hit the wall. I drove off the highway afterwards no doubt doing more damage.
    the tire and rim are done for but the radiator has a hole and the little metal coolant canister is pretty dented. The car no longer wants to shift into anything but neutral. I know I can repair it myself and get her going again but I could use some help identifying what needs to be done. Pics to come. Codes p1115, p1117, p1118 and the p0420 that’s been there.
    how screwed am I based off those codes ?
  2. JC91006
    JC91006 Senior Member
    16,766
    8,563
    On an 05, probably time to retire it and use it as a parts car
  3. Gino Veltri
    Gino Veltri Member
    413
    40
    That’s the thing I’ve got another 05 that was my parts car (ironically better body, but 299,999+ miles on her) I swap parts around them but because of the mileage I’ve always considered it the lesser of the two. Plus for a couple hundred dollars why junk a car that still runs and drives (yea I’m that guy). Plus I like fixing things and learning as I do…definitely not economical but for the knowledge. I better go pull my hood hybrid battery out of it before Costco tows it!
  4. Gino Veltri
    Gino Veltri Member
    413
    40
    #4 Gino Veltri, Mar 22, 2023
  5. dolj
    dolj Senior Member
    8,435
    4,286
    Wellington, New Zealand
    The links for all those pictures are broken. Use the "Upload a File" button below to add images.
  6. Gino Veltri
    Gino Veltri Member
    413
    40
    1E2E1645-9EF6-4364-851A-CB9255CEF6F7.jpeg F6B4D663-643C-4EA8-82D7-5D456864D15C.jpeg
  7. Tombukt2
    12,923
    2,322
    Put the 299 er on da road it should 666. Without walls etc
  8. Gino Veltri
    Gino Veltri Member
    413
    40
    Lol yeah gotta swap the hv batteries tho. Also my gas gauge on that one started blinking all the time like when you first connect a new aux battery. Ever heard of this before?
  9. dolj
    dolj Senior Member
    8,435
    4,286
    Yup, it will do that every time. It takes a few minutes to a few days to calibrate.
  10. JC91006
    16,766
    8,563
    I had similar damage to one of my cars, got totaled, too many parts needed to get it running and looking good again
  11. pasadena_commut
    pasadena_commut Senior Member
    2,604
    770
    Southern California
    You could certainly replace all of the broken components with enough trips to the junkyard, but what kind of shape is the body in? How about the suspension? Not only is the thermos squished, but the part of the car (big chunk of metal running front to back) where it is attached looks bent too.
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,038
    1,966
    NJ-USA
    Possibly low on fuel or the gauge sender in the tank is faulty- you could measure the sensor resistance and see if it's in spec per the service manual.
    You probably can fix this one - but there looks to be some tweaking needed on the frame rail plus whatever happened to the suspension when the wheel hit. Could have hurt the transmission too, depending on the angle of impact.
    If you have lots of time, tow the damaged car and use it as a donor.
  13. PriusCamper
    PriusCamper Senior Member
    12,719
    5,143
    Pacific Northwest, USA
    Looks pretty straighforward... Head to a wrecker and pull the fender, headlight, coolant canister assembly and radiator and put it in. A brand new radiator might be worth considering, but used is fine because modern day radiators don't have all the issues the ones of long had. Also Ebay sells replacement bumper covers unpainted for $100-ish and matching paint for $300ish.
  14. PriusCamper
    12,719
    5,143
    The OP clearly said they have enough skill to fix it themselves... If you know how to fix your own car the cost of replacing it is going to be significantly higher than doing the repair.
    Gino Veltri likes this.
  15. Gino Veltri
    Gino Veltri Member
    413
    40
    It’s always taken five min to calibrate. Now it won’t at all.
  16. Gino Veltri
    Gino Veltri Member
    413
    40
    The body is in terrible shape to begin with. Cosmetics are of no matter to me. But the coolant leaking is the main problem . That and the wheel is no longer straight, could that just be a bent up tie rod or does the frame rail look bent?
  17. Gino Veltri
    Gino Veltri Member
    413
    40
    This is what I was thinking but that tire is bent inward pretty bad, have t taken the time to see if it’s the frame rail or just a suspension component yet
  18. Gino Veltri
    Gino Veltri Member
    413
    40
    How would I measure the sensor, or rather where do I hook the multimeter up to? If it’s just the sensor is it still safe to drive provided I keep her filled up?
  19. Gino Veltri
    Gino Veltri Member
    413
    40
    it calibrated with a little more connection to the aux battery. this particular prius (once owned by the daughter of sir rodney king) has had some strange happenings which i somehow fixed without knowing what i did so it makes me nervous. What kind of preventative stuff can i do to a prius with an unknown ridiculously high milage (already replaced brake actuator)
  20. Gino Veltri
    Gino Veltri Member
    413
    40
    looking good was never that important to me, just drivable.
