I need to re-tile bathroom
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Mar 24, 2023.
  1. bwilson4web
    15,988
    Source: Google News -
    TGrracie and ETC(SS) like this.
    51,030
    my least favorite home improvement project :p
  3. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Oooh, that's cool.
    We re-tiled our bathroom recently. I think if I'd chosen an aperiodic monotile I'd have made the builders cry.
    bwilson4web likes this.
  4. fuzzy1
    10,335
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    737
    Monument, Colorado USA
  6. ColoradoBoo
    1,132
    737
    Not sure why that post is there...2nd try!
    Last year, I did a complete bathroom reno in our small bathroom...removed old tub and put in a soaker tub. First, I gutted it...even removed all the sheetrock (had to, anyway, to get that tub to go in) Removed the linoleum from the floor and installed hardie backer board to the floor for the 12x12 tiles. A LOT of work but well worth it...the wife found some great bathroom tile to go over her bathtub from Spain and looks very professional.
    Best of luck!!
  7. Mendel Leisk
    40,472
    Hah, Bob, knew what it'd be before I clicked.
    Interesting, looks to be a compilation, four of the yellow highlight:
  8. ChapmanF
    17,186
    waiting for expressions of disapproval from the tileboard lobby.
  9. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    The "Hat"
    13-sided, non-repetitive...
  10. fuzzy1
    10,335
    Polykites, according to the article. A tile made up of multiple kite-shaped elements. Looks to me like 8 kites. Apparently the edge dimensions are not fixed, there is some room for ratio adjustment of the basic tile shape without breaking the infinite aperiodic tiling property.
    Artists already repainting them as turtles, shirts, hats, ...
    #10 fuzzy1, Mar 29, 2023
  11. Mendel Leisk
    40,472
    Escher comes to mind.
    fuzzy1 and bwilson4web like this.
  12. ColoradoBoo
    1,132
    737
    Hopefully that tile is just concept-only...would be nightmare to try to install that and get it right! (But complex tile usually comes pre-attached to a backing that helps with installation.)
    I don't mind laying tile but I do loath plumbing stuff...especially welding copper pipes. (I'm good at it, just don't like it.) When we had our house built, in 2003, one of the plumbers messed up a weld up in the master bathroom and, before we closed, water had leaked down into the basement and ruined a big section of sheetrock on the ceiling but the builders sent a team up to fix it all and, after they were done, you couldn't even tell.
  13. ChapmanF
    17,186
    I wonder how the pre-attached-to-a-backing idea works out with an aperiodic tiling.
    fuzzy1 likes this.
  14. hill
    8,622
    Similar to floor tile you start from the center and work out, then the edges have to get cut to the borders or intersecting walls. The wacky shapes aren't really such a big deal - as the pieces will interlock. Consider the example below ..... not WHY anyone would want a wall of salamanders - but the unique geometry of how PIECES can be designed to fit together;
    I wonder if our very own salamander King here on PC has this pattern
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    And so it begins you poor bastard.....lol...
    ColoradoBoo likes this.
  16. ColoradoBoo
    1,132
    737
    LOL...so after a nightmare of a time installing it, yet another nightmare grouting all those odd-angles!! But I guess that's why contractors are picky with what customers they decide to work for...I'd have to tell whoever wanted that installed that I'm not available!
    Merkey likes this.
