Installing a limited slip differential
Discussion in 'Gen 2 Prius Accessories & Modifications' started by shtinkypuppie, Nov 12, 2013.
  1. shtinkypuppie
    shtinkypuppie Junior Member
    Torrance, CA
    Does anyone know if it's even remotely possible to install an LSD in a gen2 prius? I take her to a lot of rural areas, onto Sandy and Muddy dirt roads, ect. and I really hate digging a hole with one tire while the other sits there and wonders wwhat's happening.
    TGrracie and Minima Domum like this.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Sorry that's not possible.
  3. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    It's possible. You may not like the price. Quaife will do one-offs, but they're prohibitively expensive.
  4. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    405
    2013 Prius Plug-in
    I am actively working on this for my 2010 using the guts from a V CVT
    Toyota Prius LSD
  5. black_jmyntrn
    1,728
    405
    2013 Prius Plug-in
    #5 black_jmyntrn, Mar 30, 2023
  6. jdenenberg
    jdenenberg EE Professor
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It might be easier (but not easy) to install the rear wheel drive from an AWDe Prius and interface it with the electronics in your Gen2 Prius.
    JeffD
  7. black_jmyntrn
    1,728
    405
    2013 Prius Plug-in
    way ahead of you Jeff! :)
    now just need to 3D scan the rear end of the Gen 2 I have then align the rear subframe to see where we will place the bolts to attach the subframe. The problem though, a non-PHEV Prius doesn't have enough power to run the motor...
  8. jdenenberg
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Just add an additional battery and controller and/or switch to Lithium cells. Note that the AWDe rear drive is only active at low speeds so battery current limits may not be an issue.
    JeffD
  9. ChapmanF
    17,999
    That's not supposed to happen. The car's traction control system has control over the brake at each wheel, which allows it to brake the wheel that is digging the hole, and that forces the plain differential inside the transaxle to deliver the corresponding torque to the opposite wheel. It is the same thing a limited-slip differential tries to do by building a friction element into the differential itself, but achieved with a less complicated differential, using brakes and computers that already have to be on the car anyway.
    It sounds as if your traction control is malfunctioning. Here's an example of a Gen 2 Prius where it's working right:
    Perhaps there's an issue that can be solved so you get the full benefit of the system already built into the car, before delving into expensive mechanical mods.
  10. bisco
    51,784
  11. ChapmanF
    17,999
    There's a big difference between mostly dead and all dead.
  12. Leadfoot J. McCoalroller
    8,054
    7,537
    Pennsylvania
    2018 Prius c
