Can’t turn off auto high beams.
Discussion in 'Prime Technical Discussion' started by Zed Ruhlen, Apr 9, 2023.
  1. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    So like others the behavior of the auto high beams bothers me so I finally decided to turn it off in my 2018 prime. Except I can’t. Pressing the button does nothing. They stay on. Any ideas? Is there a software override in the settings somewhere?
  2. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    It’s a long shot but … Is the left control stalk accidentally pressed away from you towards the instrument panel? That would turn the brights on overriding the auto on/off.
    TGrracie and fotomoto like this.
  3. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    The auto high beams only operate in the high beam position on the stalk. But they cannot be turned off. When I switch to high beams the switch lites up and the indicator on the dash comes on. Pressing the switch to turn it off does nothing. I can press it to my heart's content without effect.
  4. schja01
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Thanks for refreshing my memory. Your description makes sense. The auto beams use a sensor behind the windshield. Is that blocked in some way?
  5. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    Not that I can see. But the issue ISN'T that the auto high beams don't work, it's that I can't turn them off. I don't WANT auto high beams. They are worse than useless since they randomly decide to turn off the high beams for reasons only a computer could fathom. So I want that feature off. Always. Maybe I need to pull the plug and bypass the switch altogether.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Not sure I understand the complaint.
    With my C, you can not "defeat" the automatic dimming feature......unless you pull BACK on the stalk to force them on all the time, as long as you keep pulling.
    So, I have a choice of high beams OFF.......or high beams AUTOMATIC.
    There is no ON without automatic dimming.
    When in a situation where the auto dimming annoys me, I just turn the high beams OFF.
  7. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    There’s a button to the left of the steering wheel that is supposed to toggle the feature on and off. I bet the C has one there as well
  8. Leadfoot J. McCoalroller
    8,120
    7,613
    Pennsylvania
    2018 Prius c
    Our c has a button there. When we push it, we have to select the headlight beam for ourselves.
    It works as expected.
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    I generally can't SEE the stuff to the left side of the steering column.
    I'll have to look more closely.
  10. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    I have that issue as well. The person who designed that area of the dash should be fired.
  11. CharlesH
    2,797
    1,164
    Roseville, CA
    On my Prime the is a series of buttons just below the left air vent. One of them is a headlight icon with the word "auto".
  12. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Just to be sure you're turning off auto high beams with the button. And then after you're pulling the light stalk back, correct?
    If you leave the stalk forward then your high beams will be on all the time and will not disengage for oncoming traffic or brake lights.
  13. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    That's what it SHOULD do. But it doesn't. The auto high beams does not turn off.
  14. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    Bring it to a dealership before you end up with a nasty traffic ticket for using high beams in traffic
  15. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    I won't get a ticket because the auto system works as it's supposed to. I can also turn off the high beams on the stalk. What I am trying to do is TURN OFF the automatic part so I have manual control. The switch does not do that in my car. I'm hoping someone has experienced this before and knows a work around.
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    You're right. I have that switch and it works.
    It actually brings up a warning of sorts on the display.
    You might just have a bad switch.......or a loose wire.
  17. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    So the culprit is the switch. Specifically the part that makes the switch "return" to the out position. By inserting a thin blade screwdriver in the gap around the switch I can pull up on it and make the auto lights turn off. Now the car behaves normally again. As an aside I really really REALLY despise it when half baked features attempt to be useful. The auto high beams are a bad joke. They rarely work right. They constantly turn off for random reasons like curves in the road or wet pavement.
    danielarichman likes this.
  18. Leadfoot J. McCoalroller
    8,120
    7,613
    Pennsylvania
    2018 Prius c
    Sounds like the switch got the sugary spill treatment. Glad you were able to work it out!
  19. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    I suspect the return spring was just never installed. Nothing has ever been spilled in that area. I didn't actually try to turn it off until recently so likely that has been a problem since it was new.
