Prius strange noise help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Woodsinhabitant, Apr 8, 2023.
  1. Woodsinhabitant
    Woodsinhabitant New Member
    Ny
    I
    Hi all, I purchased a higher mileage gen 2 Prius. It has a strange intermittent chirping/rattle noise coming from the engine compartment at all times even when vehicle is off. The EV part also does not work as it should it stays on for a couple of seconds and then just goes back to normal engine. Any advice appreciated thanks.
  2. dolj
    dolj Senior Member
    8,435
    4,286
    Wellington, New Zealand
    Unfortunately, you need to be more specific.
    For example, by "even when vehicle is off" what do mean?
    What exactly is "the EV part" and are your expectations for it?
  3. Tombukt2
    12,923
    2,322
    09 is a generation 2 the original body style not the coupe.? EV mode eh? I guess my EV mode has never worked I generally get between 43 and 48 mi to the gallon on a $300,000 mi vehicle that was rated to get 47.1 miles to the gallon I won't be complaining . Maybe record the noise I would say it's one of your brake pumps or your inverter pump running and maybe you're not used to that kind of noise possibly.
  4. JC91006
    JC91006 Senior Member
    16,766
    8,563
    Strange chirping and whirring noises can be associated with a brake actuator problem. All these cars have this problem eventually, as they age. Replacement cost for a new one will be around $2000 or less if you buy used part and DIY (with the right equipment to bleed the brakes after)
