Loud wind noise from 2022 Prius XLE when rear windows are down
Discussion in 'Gen 4 Prius Main Forum' started by kuffs, Apr 11, 2023.
  1. kuffs
    kuffs Now 2 Prius Owner !
    Floriduh
    Just purchased a 2022 Pruis XLE. While driving home at 45 MPH my wife rolled down the rear windows.
    The wind noise was so loud my ears hurt. Is this just the nature of this car? What can possibly be done other than not driving with windows rolled down?
    51,802
    yes, the aerodynamics of the car cause wind buffeting when the rear windows are down
    TGrracie and Pulse07 like this.
  3. Doug McC
    Doug McC Senior Member
    1,076
    414
    Midwest
    2022 Prius
    The slip-steam dynamics of the Gen 4 Prius (and some other vehicles) will cause this when you partially lower the rear windows. Quite simply, it is part of the cost of an extremely efficient vehicle. Lowering the front windows along with the rear alleviate the problem. Just try and remember you didn’t purchase a sport coupe and you will be a lot happier.
    In all honesty, my 2008 F250 exhibited the same phenomenon. FWTW
  4. kuffs
    Floriduh
    Thank You….
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    I thought all cars made wind noise with the windows open above 45 mph. They also burn more gas with the windows open at that speed.
    TGrracie and Perpetual Waffle like this.
  6. bisco
    51,802
    almost all of mine have for about 20+ years now. but i don't think our hycam does, i'll have to test it
  7. Mendel Leisk
    41,244
    This helps, doesn't have to be open a lot, changes something in the air flow.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    EVERY car I've owned in the past 20 years or so did that.
    My C does. My Ford does.
    If it hurts when you do that..............:)
    Doug McC likes this.
  9. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    Yeah, don't go too fast with only the rear windows down. The buffeting will actually start to pull on the front doors and windows.
  10. Doug McC
    1,076
    414
    Midwest
    2022 Prius
    Now there’s a new one!
  11. GoodOldBob
    GoodOldBob Member
    67
    25
    Mena, AR
    2020 Prius
    L Eco
    I just install aftermarket plastic rain visors to the tops of the doors, then, cracking the windows, even at highway speeds, is a lot more quiet than without them. Plus, you can leave your windows cracked open while parked on hot days and you can't see it from outside.....but the hot air escapes and keeps the interior much cooler.
