I got into an accident and smashed my driver side and then I drove and shredded the tire and most of the wiring in the area. Here’s what I replace and a bunch of wires that I do not know where they go. I need a nerd’s help.
If a lot of wiring needs to be identified and repaired, you might make things difficult for yourself if you are not referring to the wiring diagram: Toyota Service Information and Where To Find It | PriusChat
This is what I was looking for . You rock! Do you think the wire colors will be consistent between an 05(mine) and 08(donor)? Disregard if the answer is in the link above. Thanks again!
No guarantees, but I haven't noticed a lot of color changes within generations. Safest to use the diagram for your year.
Hey “nerd” is no insult. It just means you’re smarter than I , which isn’t saying much, so not a huge compliment either.
Well I seem to always forget I have a fully intact. 05 to compare it to. Along with the extra little lights on the bumper that the donor 08 had (back up cam, leather seats!?, etc) there’s also this weird thing. I don’t see it on my other 05.
I have read that there is an external "beeper" (makes the noise when you hit unlock on the keyfob) mounted somewhere in the left front fender area. Posted via the PriusChat mobile app.
