Cataclean and EGR Clog Codes
Discussion in 'Gen 3 Prius Technical Discussion' started by C-in-DC, Feb 21, 2023.
  1. ChapmanF
    17,186
    Welp, that's a fail, all right!
    Results are normally around 21 to 22 kPa for a freshly-cleaned working EGR system. I cleaned mine when it was down to 10 point something (which, in mine, reflected a combination of clogging and a mashed ski jump). P0401 is triggered if it drops below 0.99.
    I'm pretty sure I have never seen anyone post a 0.15 result before.
    I am not convinced your EGR valve even works.
  2. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    This makes no sense to me since the engine stalls when I input 30 steps in the egr step control test. Swapping in the oem egr with the mashed ski jump should provide a different reading. If it’s the same reading I’d think that points to the intake or something else like a clog I can’t see. If it’s slightly higher then definitely it’s a fake eBay egr valve and I’m out $110 + $270(new oem egr) + all the gaskets and map sensor.
    #222 C-in-DC, Apr 18, 2023
  3. ChapmanF
    17,186
    I'm starting to doubt my ability to even see what you're seeing or hear what you're hearing.
    Back when you posted this video:
    I really couldn't see any difference in the MAP reading from this screenshot at 1:00 into your video and this next one at 1:06, and if the sound in the video is the sound of the running engine, I couldn't hear much difference either.
    If I could only go by what I see and hear in that video, and by the later 0.15 kPa result from the monitor test, I would surely say that seeing and hearing those things would be consistent with the valve not working.
    #223 ChapmanF, Apr 18, 2023
  4. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    this is with the old egr valve. Both of them stall the engine. The new aftermarket egr valve doesn't as much as the oem one. In the previous video I was inside the car so it wasn't as pronounced.
    I'm going to drive using the old egr valve and post the results later.
  5. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    P0401 cleared with the old EGR. the egr valve still needs to be replaced since the ski jump is holding on by a thread but at least I know that's the last remaining problem. I believe The exhaust manifold leak was contributing to the code as well. Thank you again to @ChapmanF.
    The coolant temp rose to 192 f when I was going 80 mph. I don't remember what the overheating temp is.
    Conclusions:
    1. Cataclean is lipstick on a pig. It'll help you pass emissions or smog but p0420 will come back.
    2. P0401 is more annoying to figure out than p0420. It’s cheaper to replace all the gaskets in the system yourself than to smoke machine test it but it’s time consuming. Also not that much cheaper.
    3. Always get the universal cat replacement if your state allows it because it's cheaper to get your buddy that's an ironworker to weld than a mechanic. You’re going to have to weld either way Whether you get the magnaflow direct fit cat or the universal cat. You WILL have to weld no matter what the aftermarket manufacturer says.
    #225 C-in-DC, Apr 18, 2023
  6. ChapmanF
    17,186
    Yes, 15.5 kPa is a whole lot better than 0.15. :D
    It's still below the 21 or 22 typically seen after fresh cleaning. I'm guessing that'll be the ski jump.
  7. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    I got a new oem egr valve coming in tomorrow. I’ll find out if I need to extend the wiring because it’s larger. Will post readings when it’s installed.
  8. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
  9. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    I’m too afraid to open the new EGR valve.
  10. ChapmanF
    17,186
    So you're just taunting us?
  11. ASRDogman
    ASRDogman Senior Member
    7,115
    3,713
    Why would you open it up? Just install it and install the updated firmware.
    And you should be good to go. (y)
  12. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    I think @ChapmanF expressed that he wanted to see the inside of the new ones.
    I installed it already. Was getting misfires with the old one.
  13. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    That Wasn’t my intent. No.
  14. ChapmanF
    17,186
    Kidding. :)
    I really did want to see what they changed in the updated one though.
    Guess we have to wait for the next tinkerer to buy one.
  15. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    21 mpg before the new egr to 55 mpg after. New firmware was already flashed to ecu.
  16. ChapmanF
    17,186
    I wouldn't have guessed a difference that big; measurement artifact?
  17. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    I think It was from 70,000 miles ago which was when I had the original gen 3 engine. I was still only getting around 20 mph at the time. Wish I had looked into Priuschat then.
    I’m noticing this gen 4 engine is low on oil so it’s either burning or leaking. The oil pan was never changed. didn’t think the gen 4 engine needed an oil catch can too but with a gen 3 intake it looks like it does.
  18. Mendel Leisk
    40,467
    The PCV valve location on 4th gen block is the same I think.
  19. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    I kept the old cat. I see how there’s an upper and lower cat per se on either side of the sensor. The upper cat was burned out and dislodged. The lower part was still white and “clean..” If I were to weld a new cat at the upstream from the sensor what is the probability that the cat would still be bad?
  20. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    @ChapmanF do these test results mean my catalytic converter is on the verge of throwing a code or that my intake manifold and egr are begging for a cleaning? Both?
