1. ChapmanF
    17,227
    In my state you can have the engraving done for free. The state has contracted with Jiffy Lube outlets. I drove to one of them, they put my VIN in a computer (I had it written down in advance to hand to them, thinking it would save them time, but they just used a bar code scanner on the door jamb sticker, even faster) and then I pulled forward over their service pit.
    There was a quick sound like an old Centronics printer in a bathtub and then they sent me on my way. When I crawled under the car later, there was the number, stamped in nice dot-matrix figures. Seems they just used a handheld dot peen tool hooked up to their computer. So between the barcode scanning and the dot peen tool, I was barely there a couple of minutes.
    They also sprayed some high-temp yellow paint on the cat, which is apparently supposed to mean "hey doofus! this one is engraved."
  2. El Dobro
    El Dobro A Member
    7,075
    3,258
    Engraving VINs will work on cats just like the etching the VINs on windows works around here. ;)
  3. ColoradoCrow
    ColoradoCrow Senior Member
    1,097
    452
    Leawood, KS
    I
    Like a "please don't bring a gun into this gun free zone sign"?
    drash and El Dobro like this.
  4. hill
    8,628
    One thing about Engraving, is that unscrupulous folks can grind It Off most of the time. Number stamps or an electrical etching might be a better way to go.
    drash likes this.
  5. drash
    drash Senior Member
    2,548
    1,293
    Upstate NY
    Like everybody knows you can't bring a gun into the airport, yet TSA had over 6,000 people attempt to bring them in their carry-ons onto an aircraft last year (a record BTW). 88% were loaded. And there are signs everywhere including on your ticket you print out. :rolleyes:
  6. Mendel Leisk
    40,509
    I’ve read that at least in part, any sort of applying ID marking is not so much for individual deterrent, more for “the greater good”: making it easier to prosecute. Say if a fence is caught with a whole mess of cats with ID’s, hard to plead ignorance. And confirmation that recovered cats are stolen is easier, since owners can be tracked down.
    #46 Mendel Leisk, Apr 18, 2023
    fuzzy1, ColoradoCrow and bisco like this.
  7. ChapmanF
    17,227
    What I've got trouble wrapping my head around is the number of posters here who report buying used engines that show up with the VIN plate removed, and who report the used-engine vendor cheerfully, openly saying "oh yeah, we always remove those", and trying to square that with what I find in any quick google search on the subject, where I keep reading (as I would have naïvely expected) that there's never a good or innocent reason to do that.
  8. Trollbait
    12,324
    Along with that, grinding off etching isn't a markless exercise. Can't be traced back to specific car, and not easy to prove wasn't stolen.
  9. ChapmanF
    17,227
    The state-subsidized dot peening here is accompanied by a generous, sort of expressionist, spray of heat-resistant yellow paint. So there's also the chore of removing that.
    3PriusMike likes this.
  10. Leadfoot J. McCoalroller
    7,841
    7,306
    Pennsylvania
    2018 Prius c
    Huffington Post Link: Nationwide catalytic converter theft ring brought in a half-billion dollars.
    Get this: the ringleader got himself a McLaren with a vanity plate GD3 EA6, supposedly the part number for the 2nd generation Prius catalytic converter. (I went to verify this, but the Toyota parts website had its catalytic converter stolen recently and can't be driven properly.)
    bwilson4web and 3PriusMike like this.
  11. ChapmanF
    17,227
    Not the Toyota part number, but I think those are codes you find inscribed on the cat.
