What is that thing on the windshield that looks like the integrated dash camera?
Discussion in 'Gen 5 Prius Main Forum' started by rpT, May 8, 2023.
  1. rpT
    rpT Member
    45
    new york
    2023 Prius
    Limited AWD-e
    it has the exact same footprint as the integrated dashcam. The question is if I install the dashcam, do I put it next to this part? do I remove this part? It looks like a sensor of m some kind
    2023p likes this.
  2. 2023p
    2023p Active Member
    161
    102
    Here
    2023 Prius
    Pretty sure that is a camera that reads road signs etc and maybe uses lasers for depth calculations, predictions. But I'm not positive.
    I put my dash cam directly beneath it
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    Its most likely the camera that is used by the car for lane-keeping and the such. The Gen 4 has the same pod in the same position. I installed my dash cam to the right of this pod on the black dots.
  4. rpT
    rpT Member
    45
    new york
    2023 Prius
    Limited AWD-e
    sorry this is the "main" console that powers the mirror. There is a piece next to it which looks exactly like the integrated dashcam but it isn't. It looks to be powered so it is some sort of sensor.
    2023p likes this.
  5. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    It's probably a humidity sensor. Check your Owner's manual.
    2023p likes this.
  6. 2023p
    2023p Active Member
    161
    102
    Here
    2023 Prius
    ohhhh, I wasn't sure thanks for the clarification!
  7. Vtfakie
    Vtfakie New Member
    Virginia
    2023 Prius
    The integrated dashcam installs to the right of the mirror.
  8. rpT
    rpT Member
    45
    new york
    2023 Prius
    Limited AWD-e
    thanks so much. that makes a lot of sense. Does the limited need the wire harness?
  9. Vtfakie
    Vtfakie New Member
    Virginia
    2023 Prius
    I have the XLE and it does need the harness.
