Changing 2015 Prius Transmission Fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mhdriver, May 1, 2023.
  1. Mendel Leisk
    40,457
    Ah sorry, missed that. Yeah do this only on level ground.
  2. Bill Norton
    Bill Norton Senior Member
    2,126
    725
    MONW, Ks.
    I knew this would come up.
    So don't use a brand name high quality synthetic ATF. Use the dealer's generic ATF that is used fleet wide. Why?(n)
  3. Mendel Leisk
    40,457
    I’ll bite: Owner’s Manual warning, regarding damage with anything other than Toyota ATF WS?
    douglasjre, Bill Norton and Doug McC like this.
  4. douglasjre
    douglasjre Senior Member
    2,085
    698
    Null, NL
    Because of taxes you won't get $60 for the hour you'll get 45. And because the oil change place has hidden fees like waste disposal fees Florida surcharge fee it's a Tuesday morning fee and oh by the way I'm selling you an air filter you don't need fee and they let dirt bypass and now your mass air flow sensor throws a code and the few hours that you waste sitting there to watch them strip all your bolts and put in a cheap no name fluid which will cause problems later anyway we'll wind up costing you $95 plus a whole transmission plus a mess air flow sensor plus 3 hours of your time dicking around. I would do it myself Thank you very much. It would take a nurse 2 hours of overtime to pay the BS bill at the jiffy lube to get an inferior quality job done. Plus the nurse would have to sit there for a few hours and his time is worth money as well so his net loss will be far greater by taking his car to the goons with some generic lube where they strip all his hardware. My IQ is a lot higher than the collective at the teenager's first site (lube shop) of employment down the block.
  5. Paladain55
    Paladain55 Active Member
    401
    159
    The South
    Either way I'm sure a shift of overtime will make enough, typically 12 hours. Buy the 4 quarts of WS and get it done!
    douglasjre likes this.
  6. Bill Norton
    2,126
    725
    MONW, Ks.
    But if it's a DIY, why not buy a high quality synthetic ATF for a little bit more?
  7. douglasjre
    2,085
    698
    Null, NL
    Valvoline MaxLife Multi-Vehicle Full Synthetic Automatic Transmission Fluid (ATF) 1 GA https://www.walmart.com/ip/15125768
    This is my choice. It's not the OEM product and I don't assert it's equivalent. But I have used in a dozen Prius so far and never a problem. You decide what u want. If u get WS at the dealer it's guaranteed perfect every time. Up to you
  8. sambojoho
    sambojoho Proud conservative
    92
    Ohio
    I just use ramps. I measure what I drained out and put the same back in
  9. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    What happens if there’s a leak and you only drain out 1 quart? How mucj do you fill it back up?
  10. douglasjre
    2,085
    698
    Null, NL
    You're underfilling. Probably ok but thought u should know
  11. Mendel Leisk
    40,457
    Yes, if car is tilted by front-only raised, the fill hole, being towards the rear, will be overflowing sooner. How much less you can get in is directly proportional to the degree of tilt.
    Might still be within spec (attached). I could do a rough estimate of the volume less (with cad), at a few angles.
    #31 Mendel Leisk, May 15, 2023
  12. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Or have the rear on its wheels up on a hill.
  13. Bill Norton
    2,126
    725
    MONW, Ks.
    Door sill and your phone's 'angle/dangle' app is how you get level!
  14. Mendel Leisk
    40,457
    Ahh, crawling under a car jacked up on a hill is maybe not healthy. You don’t want to improvise with stuff like this.
    A level concrete slab, ramps, safety stands, wheel chocks and a decent floor jack. And even then, I like to push a thick/squat section of tree trunk under there, just in case.
    StarCaller likes this.
  15. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    No, I meant on ramps, not "jacked up."
  16. Mendel Leisk
    40,457
    Regardless, getting under a car on a slope is getting into Darwin Award territory; it is not hard to get a car raised and level (on level ground), either with ramps on the front and safety stands aft, or safety stands all ‘round (my pref).
    #36 Mendel Leisk, May 26, 2023
    douglasjre and Zaza 13 like this.
