Oil leak
Discussion in 'Gen 4 Prius Technical Discussion' started by infection, May 28, 2023.
  1. infection
    infection Junior Member
    norfolk
    Hello i have a oil leak from this two bolts. Do you know torque specs please, they are tight, anybody have same issue thanks
    #1 infection, May 28, 2023
    51,843
    i can't see any leaking
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    That's the valve cover. Oil would not be leaking from those two bolts. Probably what happened is whoever did an oil change spilled some oil and gave it the appearance of oil leaking from there.
  4. bisco
    51,843
    that's what i was thinking, but wasn't sure
  5. infection
    norfolk
    Definitely leaking I wipe few times and it's there
  6. Mendel Leisk
    41,328
    Remove those two bolts and check the faying* surfaces, clean and reinstall?
    * fancy word for contact zone between two objects
    Torque spec is 7 ft/lb, see attached.
    infection likes this.
  7. ColoradoBoo
    ColoradoBoo Senior Member
    1,231
    824
    Monument, Colorado USA
    You could replace the valve cover gasket and re-torque. (A new gasket is about $20 at Toyota). Or just keep an eye on it...looks more like a seeping then a leaking to me. (My Tundra has a seep in the rear cam tower but costs over $2,000 in labor to fix to just keeping an eye on it...it's not even leaking enough to drip, yet.)
  8. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Is this oil pressure sensor leaking oil? IMG_20230531_132401.jpg IMG_20230531_132537.jpg
