Why no rear window wiper?
Discussion in 'Gen 5 Prius Technical Discussion' started by jyoungprius, Mar 9, 2023.
  1. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    I was just being facetious. The auto dimming mirror in my 2016 was really quite awful because the spoiler in the split window casted a shadow directly over the light sensor. At least in my Prime XLE with the manual mirror I can flip it to dim. Some lights these days are still bright enough that I often need to adjust them mirror completely out of my line of sight.
    Tideland Prius likes this.
  2. Sarge
    Sarge Senior Member
    1,323
    778
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    The three cars I have owned since 1998 have all had a rear wiper which I often use, and I would certainly miss it if/when my next car doesn’t have one. :(
    With the snow we get in Canada, it is certainly a desirable feature for me, and I saw the deletion in the outgoing Prime as a drawback, even thought it was for obvious reason with the wavy rear window… However not having one is hardly a deal breaker that would stop me from buying said vehicle, I would just need to get used to it.;)
    On the other hand, I see it as the industry is trending toward a more high tech solution, with a digital rear view mirror with camera washer. A costly alternative of course - that requires shelling out for the top Limited trim - but interesting… I am still curious to see how well that washer spray will wash off road salt and other nasty stuff that would accumulate naturally. :rolleyes:
  3. Tideland Prius
    16,437
    I’ve only tried those on a Bolt I test drove pre-pandemic. It worked well. The washer on the Gen 5 seems to only spray the backup camera.
    Yeah. It’s too bad. I like a rear wiper. The one time snow started accumulated on my EV6, I used the rear defroster and it worked well to melt it.
    The Gen 5 washer seems to be only pointed at the backup camera and not the rear view camera.
    Sarge likes this.
  4. Trollbait
    12,324
    Half my driving life was in cars without a rear wiper. The only times I had to see out the rear is when backing out of parking, and I'd have cleared the snow off before getting into the car. The defroster was usually able to handle snow after that.
    On the cars with it, the rear wiper always seemed to wear out faster than the front ones.
  5. Sarge
    Sarge Senior Member
    1,323
    778
    2023 Prius Prime
    XSE Premium
    That’s unfortunate if that’s the case. :(
  6. Mendel Leisk
    40,513
    Just to muddy the waters: on our 3rd gen we've got the wiper, but it's sweep area is pretty pathetic. To the point I rarely bother with it. I wish it was better, maybe with some linkage that allowed it to sweep across the rear glass expanse, not just this postage stamp arc.
  7. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    4th gen was similarly diminutive
  8. Tideland Prius
    16,437
    The UK version has a longer wiper.
  9. Trollbait
    12,324
    Mistier climate?
    A coating of fine water droplets is real effective at blocking the view. I used the rear wiper for that far more than for snow.
    They might even get real fog lights.
  10. Tideland Prius
    16,437
    No idea. But it looked more like the front wipers of the Gen 2 than the "covered" or "shielded" ones we had on our Gen 3.
    I doubt it. They do get rear foglights of course.
  11. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Living in WI, I use the rear wiper on my Gen 3 a lot -- for snow, rain, and especially the muddy mix that tends to land there. One of the main reasons I didn't "upgrade" to the Prime was the wavy window with no rear wiper.
    I like the split rear window, because the bar across it is in just the perfect location to block tailgaters' headlights.
    Perpetual Waffle, Trollbait and Sarge like this.
  12. Alfred77L8
    Alfred77L8 New Member
    CA
    2018 Prius Prime
    Because the air of a sedan car can drop quickly and dust will not collect, the general two-box car needs a rear wiper
  13. Trollbait
    12,324
    The bZ4X doesn't have a rear wiper either.
  14. CruisnGrrl
    CruisnGrrl Active Member
    149
    127
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Sadly I've never had a rear wiper not die on any car that had/needed them (van, jeep, station wagon, actual hatchback)
    Haven't had a chance to drive my 2023 in the rain yet but I suspect the angling makes it better.
  15. hill
    8,628
    Wiper drag? I'll believe that's important to the industry - once they get rid of those drag-inducing side view mirrors for the much better option of side view cameras. The auto lobby could easily flip legislators that they are buying off anyways.
  16. CruisnGrrl
    149
    127
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    While the rear window on the 2023 is huge the view out the back window is not. In retrospect I am glad I ended up with the XSE Premium vs the XSE. I end up using the rear view mirror camera because it shows more. No need for a wiper on a window you can barely see out of anyways. The rear camera washer is nice though.
    Sarge likes this.
  17. Sarge
    Sarge Senior Member
    1,323
    778
    2023 Prius Prime
    XSE Premium
    Great to hear. (y)
    Question - does the camera washer actually clean both lenses well, or just one? (I thought it was more aligned for the backup camera). I guess it remains to be seen how good of a job it will do at cleaning off our Canadian road salt in the winter… o_O
  18. Hammersmith
    Hammersmith Senior Member
    1,969
    1,977
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I have to say I don't like the rearview camera and I'm not using it at all. I don't like my eyes having to refocus to use it then refocus again to see the road. For now, I've compromised by removing the two rear headrests to get a little wider field of view. That being said, I still think I'll appreciate it more in the winter when snow or ice is covering the rear window.
    I'm not unhappy I have the option, since I still have the ability to switch it into a regular rearview mirror with the throw of a lever.
    Sarge likes this.
  19. CruisnGrrl
    149
    127
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    It cleans both cameras, used it in the rain when it was getting foggy.
  20. ChapmanF
    17,233
    Lucky you. The angle depends on their tailgating distance. Around here, I get the ones who tailgate at the exact distance where the bar blocks their light from the auto-dimming mirror sensor, while it burns full strength undimmed into my ever-lovin' eye sockets.
