ODB 2 Reader for Gen 2 and Gen 3 Recommendation Pls?
Discussion in 'Gen 2 Prius Main Forum' started by wirelessjava, Jun 1, 2023.
  1. wirelessjava
    wirelessjava Member
    104
    Union City, CA
    Can someone recommend a ODB 2 Reader for Prius Gen 2 and Gen 3 ? I have seen one that works with your smartphone like Iphone.
    Can anyone recommend one either on Amazon ?
    --wire
  2. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    This is the one I have been using for roughly a decade. It's not cheap, but it works extremely well and it's what the high-end apps require.
    OBDLink LX OBD2 Bluetooth Scanner for Android and Windows https://a.co/d/haT7MS9
    wirelessjava likes this.
  3. PriusCamper
    PriusCamper Senior Member
    12,759
    5,168
    Pacific Northwest, USA
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,047
    1,974
    NJ-USA
    Brian1954 likes this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Budget?
  6. highmilesgarage
    highmilesgarage Active Member
    474
    175
    Kansas City
    for $50 it can do more than the basic obd2 scanners out there.
  7. JDonovan
    JDonovan Junior Member
    CT/PA
    I just purchased this one based on a recommendation from the service reps st Greenbean battery….
    I purchased it, but haven’t used it yet…..
  8. dolj
    dolj Senior Member
    8,446
    4,290
    Wellington, New Zealand
    Just on the price alone, that looks like a very basic engine scanner. It likely is not good enough to scan all of the Prius' computers.
  9. lexidium
    lexidium Active Member
    298
    140
    manchester
    Can't beat techstream.
    Get an older tablet or laptop with windows 7, a mini vci cable from amazon or somewhere and download v15 of techstream here.
    HiDrive
    Give it a minute for the download to appear . . . .
  10. mr_guy_mann
    4,047
    1,974
    NJ-USA
    I have that Autel MS309 "scanner"- it's a decent (budget) device but ONLY does basic generic OBD functions from the ECM.
    As mentioned, it can't talk to any of the other 14 or 15 systems on a Gen2.
    Not completely useless, just mostly useless.
    Now the Autel AP200 is pretty darn good functionality for the price.
    #10 mr_guy_mann, Jun 8, 2023
  11. pasadena_commut
    pasadena_commut Senior Member
    2,629
    781
    Southern California
    Another vote for techstream. It doesn't have to be a W7 PC anymore. It can run within virtualbox under W10 (and I assume W11, maybe even under Linux.) That's for the older hacked versions most people use. If you get a legal version from Toyota (expensive to be able to run it all the time, but a pass for a few days isn't bad) it will run natively on newer Windows.
    If you want to carry something in the car all the time try a Veepeak BLE+, which will talk to an app on your Android or IoS phone. The BLE model is almost the same but only supports the older Elm327 protocol.
    See also:
    Hybrid battery diagnostic and repair tool for Toyota and Lexus
  12. wirelessjava
    wirelessjava Member
    104
    Union City, CA
    I got this one...seems good so far. Also for $25 it was a good price.
  13. Carmen TheWonderDog
    Carmen TheWonderDog Junior Member
    Central IL
    Looking @ the Autel AP200 v. the Xtool Anyscan A30 series.
    So far, it looks like the Xtools has
    - more bidirectional functions(?),
    - but not key programming (limber up for some chicken dancing)
    - NO extra cost for multiple vehicles indefinitely! vs. Autel 1 vehicle indefinitely & each additional $22/yr. Ugh!!!
    - A30M functions> A30D>A30
    - A30M $ > A30 > A30D
    - Xtools A30M $ > Autel AP 200 > A30D
    per my research so far.
    How valuable/important are the additional functions the A30M has v. A30D?
    And the Autel vs. the Xtools A30 series difference in functionality?
    Or… why would I choose the Autel AP200 or Xtools A30M over the A30D, as a non-handy^ but curious/must-be-informed consumer who over researches many things & shops like a nut to get the best $.
    ^ only basics like tire changes, battery charging, replacing rv mirror, in middle of 1st HV battery swap. Nothing technical or requiring specialty tools (yet)
  14. lexidium
    298
    140
    manchester
    I now have the Launch Creader Elite 2 (specifically for Toyota)
    Free updates for life and does most of the things that techstream can do.
    xw20_driver likes this.
  15. highmilesgarage
    474
    175
    Kansas City
    I have never used my Techstream for a very long time ever since I got the Xtool A30D, for majority of the diagnostic and bidirectional features it's enough for me. Note that Xtool doesn't give INF codes compared to Autel so that's a major bummer but it has lifetime free licenses for all brands and makes which is very important to me since I service other brands of cars.
  16. mr_guy_mann
    4,047
    1,974
    NJ-USA
    It depends - on what you want or "need" a scantool for.
    The Autel AP200 has FreezeFrame data and INF codes (where applicable), most brake system service functions and immobilizer functions. (TPMS sensor programming didn't work for me).
    The Xtool A30 series has bidirectional controls, more service functions, but no FF data, INF codes, or immobilizer.
    Lots of folks have fixed cars without either, but there are times when having those capabilities is really handy.
    HV battery isolation fault code? I want the INF codes.
    No start? I want to turn the fuel pump on (easily). Coolant Heat Storage code? Command the coolant pump on or off.
    The ThinkCar - ThinkDiag is "the whole enchilada" (ie, pretty much does everything), but I don't want that functionality enough to pay a continuing subscription.
    That, and all of these need accounts set up and periodic login in order to work. So lack of network connectivity (or having their server offline) will cause problems.
