2023 Prius Reviews
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Dec 14, 2022.
  1. vvillovv
    vvillovv Senior Member
    4,318
    1,498
    NY
    There're many times, a ton of variables to put together when trying to explain exactly how and when the Prius and even more so the prime will behave one way or another, which often get left out or forgotten in a posts description.
    I leave stuff out too, it's frustrating, and i'm still learning new stuff about how the Prime behaves 6 years in. One example, I've still, never really used EV Auto enough to have a clue about how it's programming is setup.
    And I do agree 100% with what @Trollbait posted above. That without a long enough and / or steep enough hill or mountain to drive down, the Prime and PiP give the appearance they will not charge up out of the PHEV's hybrid reserved portion of the traction pack on their own. Where as on a longer decent the driver doesn't need to switch modes to get enough regen into the pack for the car to start working in EV mode again. Does that sound right to you @bisco ? It's been a while since I've been behind the wheel of a PiP.
    51,031
    Yes, that sounds right. But I have never driven down enough small hills to know if it uses all the regeneration, or if there simply isn’t enough
  3. vvillovv
    4,318
    1,498
    NY
    The trouble I've noticed when out of EV miles is the amount of regen needed to get back into the EV usable space, a minimum 1% EV which is about 4/10ths of a mile EV (in my Prime at 25 miles EV estimate after fully charged, for me currently), last time I looked. And the car uses regened voltage pretty quickly, (even faster it seems to me) than the same amount of charge acquired from the plug.
    Those regen observations to me makes it seem even harder to get back into the usable EV range. especially on multiple smaller mounds (can hardly even call um hills) like the ones around here, after running out of EV range all together.
    I've seen voltages shown in DrPrius while in HV mode with no EV miles available as low as 322 volts when really testing just how low it will go. The voltages bounce around a lot down that low, with voltage rebound and stuff like that. i think it's mostly the nature of how Toyota programmed those limits. EV range (for me) cuts out at 330 volts consistently with the lowest I've seen ( 325 volts that rebounds to 330 volts as soon as the load is removed.
    edit And I was always under 15mph in EV mode to capture voltages that close together, at faster speeds the EV cut off voltage seems higher and is harder to spot, /edit
    Seeing that sfuff in the car reinforces the stuff others have learned when reconditioning packs.
    #283 vvillovv, Jun 7, 2023
  4. bisco
    51,031
    i've never gotten back into ev, but we're flatlanders around here.
  5. daisy555
    daisy555 Senior Member
    1,644
    691
    CT
    Another new upbeat review on the Prime…
    Preebee, Roqu3 and mountaineer like this.
  6. bisco
    51,031
    if i had to park in the sun, that would be great, but i always seek shade.
    did he say he got 2-4 miles of solar charge, then later say if you're someone who parks outside all day, that's 5-6 miles you can drive home with?
  7. Preebee
    Preebee Senior Member
    867
    769
    Midwest
    2023 Prius
    What an exciting review! Thanks for posting!
    Really jelly of that Prime with solar, but $42k...:censored: Need a Canadian connection. Those lucky dogs! :(
  8. vvillovv
    4,318
    1,498
    NY
    I got a kick out of his snicker after he gassed it at 13min 25sec. Kinda says it all for me.
    Preebee and daisy555 like this.
  9. Preebee
    867
    769
    Midwest
    2023 Prius
    Super car owner blown away by the new Prius. "Would absolutely own this car." Said outside of the Crown, this is the quietest Toyota.
    daisy555 and Perpetual Waffle like this.
  10. mountaineer
    mountaineer Active Member
    144
    113
    Ontario
    2019 Prius Prime
    Another glowing review
  11. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    Consumer reports,He he says cargo space is smaller! And a lot of the other things paid reviewer’s have mentioned! I still don’t see a lot of real owner YouTube reviews?
  12. bisco
    51,031
    yes, the cargo space and back seat. thoroughly covered here. i haven't seen an owner review either.
    the problem, as i see it, is that these reviewers are all gear heads. they love the bew styling, the power and the electronics (but are clueless as to toyotas poor electronics history)
    the functionality of the car means nothing to them, and of course, they still won't own one themselves.
    samsprius1 and Trollbait like this.
  13. JoeBlack
    JoeBlack Member
    110
    89
    Europe
    2021 Prius PHV
    Thomas finally got his hands on PHEV variant in Europe.
    Tideland Prius and Gokhan like this.
  14. Gokhan
    Gokhan Senior Member
    5,639
    2,225
    Paramount CA
    Ha, I wouldn't expect from Toyota a quality-control issue like an off-centered steering wheel! That is awful for a brand-new car!
    Perhaps I should wait for the 2024 model year until they fix these quality-control issues.
  15. bisco
    51,031
    I like how so many reviewers pose for the Prius
  16. Hammersmith
    Hammersmith Senior Member
    1,965
    1,970
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Meh. This was obviously from a Toyota press event. Those cars are transported all over the place and get put through the ringer by the reviewers. I'm more likely to believe a reviewer knocked the alignment out, or Toyota had to have it realigned between events and the alignment shop misaligned the wheel because it was done in a hurry.
    The counter argument would be that wouldn't Toyota be certain that a car on a press tour be maintained perfectly? But if those cars are bouncing around Europe with a few press events a week and a dozen reviewers driving each car at each event, it's easy to think that a car could get lightly damaged and they not catch it right away.
    daisy555, Roqu3 and JoeBlack like this.
  17. daisy555
    1,644
    691
    CT
    Considering the slow rate of production I’m wondering if there will be any changes to 2024 model.
    Gokhan likes this.
  18. JoeBlack
    JoeBlack Member
    110
    89
    Europe
    2021 Prius PHV
    I don't really see changes made for 2024, they pretty much already set quotes in some regions for 2024.
  19. Tideland Prius
    16,430
    12.3kWh/100km is great efficiency, especially for a media event.
    JoeBlack likes this.
  20. Preebee
    867
    769
    Midwest
    2023 Prius
  21. Preebee
    867
    769
    Midwest
    2023 Prius
