P0401 code help needed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2010_Prius_Bro, Jun 13, 2023.
  1. 2010_Prius_Bro
    2010_Prius_Bro Junior Member
    44
    maryland
    Thanks RJParker for the better picture of the VIN plate on the engine. That EGR schematic is of great help. I'll need to bring out my multimeter and test for continuity. Visually everything looks good but wiring seems to be the only thing I haven't really checked out yet to determine whether the EGR valve is getting the power it needs to open and close the valve. Thanks for the great recommendation. I have been trying to get the EGR step test done but my Techstream keeps crashing! Need to find a more stable version. Currently using version 13.00.022.
  2. Mendel Leisk
    40,467
    I think to see that engine VIN plate you'd need to raise the front, take off underpanels. Probably the stamped aluminum underpanel at back of engine bay is the best bet. I tried from above, dangling a lamp and snaking a mirror in there; nigh impossible to even find it, let alone read.
  3. 2010_Prius_Bro
    44
    maryland
    You're right it that it is a tight fit. I do have an endoscope camera that I can attempt to snake back there to try and make out the numbers. Otherwise, I have an oil change to do very soon so I will check it from under the car if the scope doesn't hack it.
  4. rjparker
    9,505
    5,819
    You will need a borescope regardless. If the engine has been replaced it is likely to have the vin plate removed as salvage yards don't always want you or law enforcement to know the miles, year or current legal status of the engine. Used engines shipped in from Japan (JDM) never had the US specific vin plate.
  5. 2010_Prius_Bro
    44
    maryland
    Gosh, I am learning so much from this forum. I didn't know salvage yards were allowed to remove the VIN plates. It seems to me like filing off a serial number of a gun so that it becomes untraceable. So sad!
  6. rjparker
    9,505
    5,819
    If its not burning oil or rattling occasionally in the morning, a replacement engine is a plus not a minus. It could add serious value "engine rebuilt 50,000 miles ago" since the engine is the weak spot on a gen3.
    2010_Prius_Bro likes this.
  7. ChapmanF
    17,186
    Right—now that you know the MAP sensor works, not only do you know it isn't the problem, you know you can rely on it as a diagnostic instrument as you continue to hunt down what is the problem.
    In other words, you know the EGR Bank 1 test fails because the measured MAP doesn't change by a large enough amount. And you know that's not because of a sensor problem, so you know the pressure really is not changing by a large enough amount.
    That means not enough exhaust gas is flowing through the system, whether because the system you think has no clogs still has a clog somewhere, or because the valve you think works is not opening. So you double back and check those assumptions again, knowing you will find something you missed one place or the other. That was my suggestion.
    Do you have Techstream or another scan tool that can command the EGR valve position?
  8. Mendel Leisk
    40,467
    This was brand new?
  9. Mr. F
    Mr. F Active Member
    386
    253
    Washington
    @2010_Prius_Bro indicated in #1 they replaced the valve, and in #11 that the previous owner did.
    If the previous owner was indeed an unreliable narrator, I would verify their claims and not assume any of them to be true. They may have thought a salvage yard pull qualified as "new".
  10. 2010_Prius_Bro
    44
    maryland
    Thanks for your wisdom. I will double back and recheck throughout the system. Yes, I have acquired a stable version of Techstream and will try to command the EGR valve position. Will report back.
  11. 2010_Prius_Bro
    44
    maryland
    Mendel, EGR valve in the car is new and shiny. Come to think of it, the only thing I have not determined is whether this is an OEM part or cheap aftermarket. I don't have the car with me at the moment to be able to verify this. If this is an aftermarket part, it could explain why this EGR valve may not be working properly and causing an P0401 code to pop up. I guess I can't assume brand new parts are guaranteed to work 100% especially if it is a cheap aftermarket replacement.
  12. Mendel Leisk
    40,467
    Where’d you get it?
  13. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    hoping it wasn’t an aftermarket egr valve from eBay.
  14. 2010_Prius_Bro
    44
    maryland
    Mendel, I bought this 2010 Prius about 3 weeks ago at 208K miles for my son. The previous owner already had this EGR valve installed. He owned this car for 3 years and drove it only for about 12,000 miles. He had told me that he had a check engine light (P0401) turn on and off intermittently during his ownership. I am the third owner of this car. In my mind this would be an easy fix by just cleaning out the EGR cooler, EGR pipe, and intake manifold. After all this, still looking for a solution. Still need to check the circuitry of the EGR valve, whether the EGR valve is OEM or aftermarket. Problem is my son works nights so when I get home I don't see the car until early morning when I leave for work. Not really enough time to work on it to do diagnostics.
  15. 2010_Prius_Bro
    44
    maryland
    I confirm that it's an aftermarket EGR valve that is made in China. There are no markings in the area where there should be a part number. This could very well be the cause of my P0401 problem. Thankfully, the previous owner left me with the original EGR. I will open it, clean it up thoroughly and make sure the valve is opening and closing properly. I will then put this original one back to see if it works. If it doesn't work, I will need to purchase one.
    Mr. F likes this.
  16. C-in-DC
    C-in-DC Member
    486
    68
    Washington D.C.
    @ChapmanF and others helped me figure out the one I bought off eBay was a dud. If you can use the old egr valve till you can get a new oem or aftermarket through a store(that will be forced to warranty their product), that’s what I suggest you do. I’m using my old egr valve with a mashed ski jump till I can afford a new oem (274 bucks).
    Perhaps there’s a previous thread mentioning a good aftermarket brand.
  17. 2010_Prius_Bro
    44
    maryland
    Sound like a plan! I am going to cross my fingers and hope I can still get some life out of it.
  18. Mendel Leisk
    40,467
  19. 2010_Prius_Bro
    44
    maryland
    Over the weekend, I was able to get an used updated EGR valve (part no. 2562037120) from a salvage yard. I cleaned it out the best I could and replaced the "new aftermarket Chinese-made EGR valve" that was previously installed. After a few test drives I am happy to report to @ChapmanF that my readings are now within normal limits (see pic below) and no longer getting a P0401 code. To summarize, the original OEM EGR valve failed. The previous owner had it replaced with a cheap aftermarket before selling it to me. He did not disclose to me that this was an aftermarket replacement so all the while I thought it was OEM and didn't realize it until I posted this thread. Thanks for those who shared their opinions! The lesson here is always replace with OEM, especially with an EGR valve.
  20. ChapmanF
    17,186
    That's at least the second post I think I've seen suggesting that some of the aftermarket EGR valves are just plain not fit for purpose.
    C-in-DC likes this.
