Anyone install a active sub under 2023 passenger or driver seat?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by 2023p, Jun 29, 2023.
  1. 2023p
    2023p Member
    147
    92
    Here
    2023 Prius
  2. PhoS
    PhoS Active Member
    254
    208
    Nowhere
    2023 Prius
    Limited AWD-e
    There isn't enough space under the passenger seat. I installed a JBL basspro nano into the rear storage. It was fairly straight forward but I've done similar installs a million times at this point. You will need a custom harness to run outputs from depending on what stereo you have. It should be no problem for an experienced installer.
    Gen 5 Prius and Prius Prime owners thread | Page 14 | PriusChat
    2023p likes this.
  3. 2023p
    2023p Member
    147
    92
    Here
    2023 Prius
    nice! Thinking the 8" hideaway kicker, looks a bit bigger than the nano deminsion wise, too bad it won't fit under the seat.
    Looks good!
    If you have a chance and take a look
    https://www.crutchfield.com/S-s2lfgsxRf7k/p_20611HS8/Kicker-11HS8.html
    Does the extra wiring it comes with cover all needed to install without purchasing more stuff? From your experience.
    I have the LE, non jbl stock head unit. Hmmm
  4. PhoS
    PhoS Active Member
    254
    208
    Nowhere
    2023 Prius
    Limited AWD-e
    I'm not familiar with the setup in the non-JBL cars, is there also an amplifier under the driver seat on those? If so you can tap into the speaker wires there. As I said before I used a jumper harness to tap in rather than cutting into the factory wires.
    Depending on where you put the sub some of the included stuff sounds like it might work but I think you'll end up needed some extra wiring. This is all standard stuff you could get online, at a car audio shop, or even a good hardware store.
    2023p likes this.
  5. 2023p
    2023p Member
    147
    92
    Here
    2023 Prius
    I'm not sure but I don't think there's an amplifier under the seat. Going to meet with installer for consultation Sunday morning and report back.
    Thanks for the info/replies!
  6. 2023p
    2023p Member
    147
    92
    Here
    2023 Prius
    So.. for what it's worth. When I raise my driver seat like 2 pumps. There is perfect room, barely but perfect fit for the Kicker 8" Hideaway powered "sub" under my seat.
    Having it Installed on the 17th. Will report back. Presuming it will make a decent amount of thumping.
    Decided to have the switches and dials face the front of the car, under the seat, able to tweak them if needed, which will be never after "tuned". Able to slide seat back and forth etc
    I'm not tall, so I don't notice the seat being raised at all.
    The kicker comes with all the wires and harness needed to install, no need to purchase a thing else.
    Figute having it in there instead of trunk somewhere will be a tasty difference in sound. I do not know
    PhoS likes this.
  7. PhoS
    PhoS Active Member
    254
    208
    Nowhere
    2023 Prius
    Limited AWD-e
    Nice, I wonder if the drive side is a little deeper? I couldn't test it since I have the JBL amp there. You could always put like 3/4" spacers and longer bolts under seat mounting points so the seat can be fully lowered without mashing the sub.
    2023p likes this.
  8. 2023p
    2023p Member
    147
    92
    Here
    2023 Prius
    That's a really good idea, I definitely hadn't even thought of that solution. Absolutely going to do that! Thank you
  9. Rick44
    Rick44 New Member
    Arizona
    2023 Prius
    Hello Audio Enthusiasts,
    I'm a huge audiophile and it was a must to upgrade my sound system. I used a powered 8 inch Bazooka tube and installed it under the cargo floor. I carved out the Styrofoam (right side when facing the rear of the vehicle) and it fits like a glove. I have it firing to the rear of the vehicle. No straps required and I bought the optional volume and frequency adjustment. I had a professional installer wire it up and they did an awesome job. The bass is tight and not boomy. You'll get far superior bass than under a seat. It still has the flat floor and it doesn't take up precious cargo capacity. Try it, you won't regret it!
    Bobbybob and reallyreal like this.
  10. kellyj
    kellyj Junior Member
    43
    22
    Orlando, fl
    2019 Prius
    Photos please
    Bobbybob likes this.
