Official (OEM) Toyota Prius 2016 (Gen 4) oil-change instructions
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Gokhan, Mar 4, 2016.
  1. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    Hi
    Any advice about the oil change for 70km prius 2017, would you prefer liqui moly or totachi? As here most of the prius owners recommend to use totachi, but no one clarify the reason other than that totachi is not reiterated, while lqui moly is reiterated oil.
    Noting that winter here is not so cold and maximum 35 degree in summer.
    I got confused, any advice please
    Thank you
  2. Gokhan
    Gokhan Senior Member
    5,637
    2,225
    Paramount CA
    Liqui Moly 0W-20 flavors are great. More OEM approvals (Jaguar etc.) mean higher quality, but even the cheapest Liqui Moly 0W-20 flavor is fine in the Prius. Totachi 0W-20 has dexos1 approval and is fine in the Prius. Don't use thicker oil in the Prius. I don't know if 0W-16 is approved for the older Gen 4 models, but I would recommend it over 0W-20 if approved.
  3. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    Yes 0-20 is the recommended, but which brand, liqui moly or totachi, and what is the difference between them, why most of the prius owners recommend totachi??
  4. Gokhan
    5,637
    2,225
    Paramount CA
    Either is fine. Totachi is more mainstream. Liqui Moly is more fancy. If you want the most premium, use the Jaguar-approved 0W-20 flavor of Liqui Moly. Totachi is GM-approved (dexos1).
    Limey Geoff and Fadi1 like this.
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    737
    Monument, Colorado USA
    I've never used either but used just about everything else, even Amsoil. The difference in synthetics in Mobile One, Valvoline, Quaker State, etc. is negligible for normal cars (IMHO)....the only major differences are seen in extreme use like in racing engines running at a bazillion RPMs.
    The important thing with oil changes is to do it faithfully and often...procrastinators who go way too long between oil changes come to regret it, almost always.
  6. Drew Aldridge
    Drew Aldridge Junior Member
    I have a 2017 Prius Touring 4. I changed the oil the other day, and my slotted 64mm was way too large. The smaller generic multi sided wrench did fit however.
    Does anyone know the size and where I can order the correct sized slotted wrench to fit my Prius.
    Thanks.
  7. Mendel Leisk
    40,472
    I’m sceptical of the efficacy/need for a slotted wrench, and suspect if you measure inside face-to-face dimension of yours it would come in at 65 mm or more.
    FWIW I use a Honda filter wrench, heavy stamped steel, and aforementioned measurement just over 64 mm. Works well, a snug fit. They’re available through Amazon and I’m sure through any Honda dealership parts department.
    (part no out-of-date) 73D535C7-2668-420C-B784-77460FF020C9.jpeg 602AB9B1-793F-47BB-9B2C-B48694DA8151.jpeg
    #167 Mendel Leisk, Aug 25, 2021
  8. Gokhan
    5,637
    2,225
    Paramount CA
    The genuine Toyota oil-filter wrench (part no. 09228-06502) is 65 mm. Note that 65 in the part no. denotes the size of the wrench. (There are also genuine Toyota oil-filter wrenches that are 75 mm and 100 mm, with part nos. 09228-07502 and 09228-10002, respectively.) Any halfway decent 65 mm cap-type oil-filter wrench resembling the genuine Toyota oil-filter wrench will work with the smaller genuine oil filters for Toyotas.
    Here is the photograph of the genuine Toyota oil-filter wrench part no. 09228-06502, with 65 (mm) clearly stamped on the wrench.
    #168 Gokhan, Aug 26, 2021
  9. ColoradoBoo
    1,132
    737
    I've owned a Scion and Yota's and all take a 14mm drain plug wrench but there are two different sizes of canister oil filters.
    If you want to turn a 30-minute oil change job into a few hours, accidentally pop out the metal spring and bracket from inside of the canister when replacing the paper filter! (Yes, it's replaceable but a bit tricky!)
    Doug McC likes this.
  10. Yakup
    Yakup New Member
    New Jersey
    Hello. I own a 2016 Prius on 100k miles. I bought it 2 months ago and I asked them when did they change the engine oil they said just before they sold the car and they used 0w30 oil while they should have used 0w20 according to manual. I have driven it for 2.300 miles since I bought and I’m thinking getting an oil change with a 0w20 oil. Which brand of oil and filter do you recommend? Do you recommend Mobil 1 and Fram oil filter? Should I go to Toyota dealer for oil change?
  11. Gokhan
    5,637
    2,225
    Paramount CA
    You can purchase oil-change and tire-rotation packages from the dealer, such as three for $150.
    I prefer Toyota Genuine Motor Oil (TGMO) because of high moly, high boron, and polyol ester (POE) added as requested by Toyota. If not going to the dealer, Mobil 1 Extended-Performance with the extra antioxidant (AO) is good. Toyota OEM oil filter is failsafe. If not, Fram Ultra with highly efficient filtration is good, too.
  12. Mr.Vanvandenburg
    1,320
    540
    2020 Prius Prime
    I have found aftermarket cartridge filters not the same as Toyota brand. Toyota has very small clearance from the media to center tube, others can have a large gap. The small clearance aligns the top and bottom holes and lends support to the media. On the Toyota TRD it has an inner steel center tube, the gap, then the fixed cartridge center tube on the cap. Two center tubes.
    I actually threw away a new aftermarket filter costing more than the Toyota because of the gap and both end cap holes not lining up to the center tube.
    Care care nut makes a big deal about not tampering with the cap center tube and removing it. Throw the cap away and buy only the Toyota replacement, it’s not worth saving money in the wrong place.
    ColoradoBoo and Doug McC like this.
  13. Doug McC
    Doug McC Senior Member
    1,044
    396
    Midwest
    2022 Prius
    If you are unable to do the oil change yourself, and don’t have a reliable local mechanic, then yes, go to the dealership. DON’T use a fast lube place or another box store oil change place (such as Walmart). It’s a simple job that you could probably do, but as simple as it is those other places can REALLY screw things up and end up costing a whole lot more than the dealership.
  14. ColoradoBoo
    1,132
    737
    Toyota dealers DO replace filters with OEM Toyota but they don't use Toyota oil....all the dealerships I've ever dealt with, in the USA, just use the cheapest bulk oil they can find. (Saves them money)
    Personally, I'd use just about any other filter but Fram....don't like their cheap stuff at all. Mobile One and Wix are just about as good as OEM IMHO.
  15. Mendel Leisk
    40,472
    That's a little presumptive? My nearby dealership claims to be using Toyota Motor Oil, both bottled or bulk. They do offer Mobil oil as well. I was purchasing bulk (Toyota) oil from them for quite a few years, till the price went through the roof. Using Costco's Kirkland oil at present.
    #175 Mendel Leisk, Jul 21, 2023
  16. Gokhan
    5,637
    2,225
    Paramount CA
    This is very strange. You should complain to Toyota. All the dealers here always use TGMO, and they show the part number on the receipt. My dealer currently uses bulk TGMO 0W-16 (55-gallon drums) for my car.
  17. Doug McC
    1,044
    396
    Midwest
    2022 Prius
    My experience matches yours, and I agree that it seems pretty strange. But then again, I apparently don’t live in the “Prius Chat Universe”! :whistle:
    Gokhan likes this.
  18. Yakup
    Yakup New Member
    New Jersey
    While my car is getting closer to a new oil change, should I replace the oem filter which I installed 6.000 miles ago? How many miles does it last?
  19. ColoradoBoo
    1,132
    737
    Absolutely! And I was pleasantly surprised to see the YZZN1's on the shelf at my local Walmart so I'll grab a few for the garage stash whenever I run over there. (3 of our cars take them, which is very convenient.)
  20. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Make sure that they are "Made in Thailand." Accept no substitutes!
    ColoradoBoo likes this.
