1. BurtMacklinFBI
    BurtMacklinFBI New Member
    Georgia
    My wife just bought a 2012 Prius a couple months ago. It has 163,439 miles on it. Runs great except about a month after it was purchased we noticed that anytime it got up to around 70 mph the overheat light came on. It would also occasionally do it under heavy and extended acceleration, but for the most part if it stayed out of PWR it was totally fine. You could literally drive it for hours in town or at moderate speeds (40-60) and the coolant temp would stay right in the sweet spot, but the light comes on like clockwork at 70 mph and coolant temp skyrockets to over 200. I ran a scan and it said coolant temperature sensor, so I replaced that and it still came on. Flushed the radiator twice, bled the air out of the system in maintenance mode, and just about every other quick fix that was recommended on YouTube to no avail. Should I check out the thermostat or water pump or both? I just wanted to get the opinion of some more experienced prius owners before I start digging into things.
  2. Brian1954
    Brian1954 Senior Member
    2,010
    783
    South Central PA, USA
    First, check to make sure that the air flow through the radiator is not blocked by any debris. If that is okay, then I would look about replacing the engine water pump. I would buy the OEM pump.
    BurtMacklinFBI likes this.
  3. Tombukt2
    12,682
    2,264
    Someone here locally just bought an impeller off of Amazon for the factory water pump usually the impeller the plastic peels off the metal and it gets stuck in the bore it spins in. Drop another smooth impeller in there and then it works fine usually You can test it off the car plugged into the car by turning the car on and watching the impeller spin smoothly like the one you just took out couldn't.
  4. Mendel Leisk
    40,975
    Third gen's have a couple of possibly relevant issues:
    1. The engine coolant pump (aka water pump) are prone to crap out, anywhere between 160K~200K miles. It's got a plastic impeller that becomes difficult to turn, or just comes apart.
    2. If the EGR system (including intake manifold EGR passages) has not been cleaned, the head gasket fails, around the aforementioned miles.
    Buying a 3rd gen with those miles, there's decent odds it's got either of those, perhaps compounded by head gasket sealer poured into the engine coolant, to mask symptoms.
  5. BurtMacklinFBI
    Georgia
    Whats the best way to check the airflow?
  6. Mendel Leisk
    40,975
    Just eyeball it for obstructions? Dangling a light down on the insde, then looking from the outside, might help.
  7. BurtMacklinFBI
    Georgia
    Thanks for the help everyone. Finally got around to taking everything apart today and the water pump impeller was the culprit. Runs just fine now!
  8. Brian1954
    2,010
    783
  9. pandion
    pandion New Member
    Florida, USA
    I had this exact problem a few weeks ago. I also replaced the ECT sensor first without success. It's the water pump rotor. It's split, rubbing in its well, and not providing adequate coolant flow at highway speeds. It's a relatively easy and inexpensive fix if you replace rotor only. I detailed my diagnosis and fix in the thread below. While I had the coolant drained, I also replaced the thermostat and cleaned everything EGR related; cooler, pipe, valve, intake manifold.
    P0117, intermittent overheat, and water pump rotor | PriusChat
