EV 'spare gas can'
Discussion in 'EV (Electric Vehicle) Discussion' started by bwilson4web, Aug 18, 2023.
  1. bwilson4web
    16,109
    REQUIREMENTS
    • Charging EV without a charging network.
    • Electric power when parked anywhere.
    MARKET RESEARCH
    I have been shopping for a portable generator (aka., EV equivalent of a spare gas can) that could be independent of any charging network and found:
    • Sportsman Gasoline 4,000W Portable Generator
      • Sustained 3,500W
      • 1,750 W, 10 hrs, 3.6 gallons = 17.5 kWh
      • 70 mi ~= 4 mi/kWh * 17.5 kWh (@4 mi/kWh)
        • ~20 mi/gal = 70 mi / 3.6 gal
    • 23" x 20" x 18"
    • 101 lbs
    • 120 VAC NEMA TT-30 (3.6 kW)
      • ~14 mi range per hour (4 mi/kWh)
    • ~$300 purchase
    • Air cooled
    OPERATIONAL SCENARIO
    Both of my EVs, a 2019 Tesla Model 3 and 2017 BMW i3-REx, have a 2" receiver hitch and one shared, removable, 2" rear carrier platform. Mount the generator on platform with folding, adjustable legs so only 50 lbs has to be raised at a time.
    The 2017 BMW i3-REx has a range extender with ~88 mi gas range. But it does not have a range extender engine mode with power outlets when parked. Once parked, It has a limited, 150 W, inverter on a very small 12 V battery.
    My 2019 Tesla Model 3 Std Rng has a 48 kWh, traction battery with no power outlets. There is a 150 W, 12 V source from a very small battery.
  2. FalconSeven
    FalconSeven Active Member
    150
    114
    Why wouldn't you carry a solar generator and avoid gas altogether?
  3. bwilson4web
    16,109
    My Tesla requires a minimum of 6 A and the requirement may occur when there is insufficient solar flux. This is a 'spare can' solution which means 24x7. There are solar-to-battery systems that have much lower kWh capacity, heavier, and cost a lot more.
    You are asking the right question.
    I had considered higher energy density cells like those used in missiles. These primary cells often use a chemical 'fire' to melt the electrolyte and generate a great deal of energy in a short time. The light weight and high energy solve the problem BUT they are expensive and one-time only use.
  4. FalconSeven
    150
    114
    I think you're looking at it wrong.
    If you precharge the batteries in a solar generator and then hook up the panels, you should be able to maintain the amperage while the pack discharges. Of course, it all depends on the size of the battery pack and the number of panels.
    My ecoflow solar generator has ~1,800 has a 2000 wh bat. That should be enough to change either our niro EV or Id.4 for almost 2 hours before depleting the pack. That doesn't account for the solar input, but I wouldn't bank on that.
    I only have a 6 mile commute to work and I've often wondered if I could commute purely on solar. I think I might just be able to do it, but it'd be really impractical.
  5. bwilson4web
    16,109
    Can you provide a product URL so I can check?
    The portable energy storage batteries I've seen reviewed are heavier for less energy. Weight and power are critical requirements.
  6. FalconSeven
    150
    114
  7. bwilson4web
    16,109
    Thanks!
    Specs from the web page:
    • Capacity - 2048Wh
      • two DELTA 2 Max Smart Extra Batteries
      • AC Output - 2400W total
      • (Surge 4800W)
      • X-Boost 3400 W
    • Dimensions - 497 × 242 × 305 mm /19.6 × 9.5 × 12 in
    • Net weight - 50 lbs (23kg)
    • Cost - $1,749
    Capacity 2 kWh versus 17 kWh. Weight 50 lbs vs 101 lbs. Cost $1,749 vs $300.
    So it has half the weight for 1/8th the capacity for 5 times the cost. You're right, impractical for an 'EV spare gas can.'
    #7 bwilson4web, Aug 18, 2023
  8. FalconSeven
    150
    114
    I'm not so sure... it's got enough juice to get me to a charger if needed.
    And, here's the kicker, I'm not going to sit around for hours and hours and hours while a generator makes a racket. Better things to do!
    bwilson4web likes this.
  9. bwilson4web
    16,109
    No problem. We have different requirements.
  10. Trollbait
    12,419
    Will the EVs accept the output of that generator? Is the sine wave clean enough?
  11. bwilson4web
    16,109
    If not, I’ll return it. Can you share the voltage waveform from that generator?
  12. FalconSeven
    150
    114
    I guess it is. You can see it being used to charge a Model 3 here:
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    Simple answer:
    Not enough power to be practical for most people in
    most common situations.
  14. bisco
    51,488
    that's pretty sweet, how many miles will it put in an ev?
  15. sylvaing
    sylvaing Senior Member
    1,208
    514
    I have a 10000Wh "portable" (it's on wheels) non inverter generator. I plugged it to the portable charger of my Modele 3 using a NEMA 6-30 to L14-30 converter. It charged no problem from 5A to its maximum output of 30A. It's my backup plan at the cottage if I ran out of power there.
  16. fuzzy1
    10,337
    You won't be waiting hours and hours because your EcoFlow battery can't last that long. It will be drained empty in under one hour.
    But its X-Boost power capacity is not any larger than Bob's gas generator, so you won't be adding miles any faster than his proposal. If you are within about 6 miles of a charger (or at very best, 8 miles, ignoring conversion efficiency losses), you could get to a charge station at about the same time he could. But at any greater distance to a station, you simply can't get there. He can go many times your distance.
    I don't know where you drive. I commonly drive in places where 6-8 miles isn't enough to get anywhere close to the next gasoline, let alone the next publicly available electric charging station. But at least by being willing to backtrack if necessary, Bob's proposal should be able to allow recovery from "user error" from any point along these routes:
  17. bwilson4web
    16,109
    I had looked at RC-sized, turbine engines because of small size and low weight. But costing over $2,000, made them an expensive choice. Furthermore, I would have to come up with a generator and inverter. See XICOY X45 Micro Turboprop.
    There are some interesting Wankel generators also smaller and lower weight. But so far, I'm only seeing manufactured units output 72 VDC or lower. Prices are just double the unit I'm looking at. I did see one 120 VAC, 3 kW unit on Ebay that is is no longer in production.
    A Google survey suggests ~$300 in the 3-4kW range is the optimum price-performance range. Lower priced, ~$250, are in the 2kW range, half the power.
  18. FalconSeven
    150
    114
    In the wilderness of suburban Philadelphia, you're never more than a few miles from a charger.
  19. Trollbait
    12,419
    This the other side of getting a PHEV and driving all your miles in EV. Maybe you got the wrong car?
    John321 likes this.
  20. bwilson4web
    16,109
    Two weeks later, I bought a 2017 BMW i3-REx which is a great, urban car. The short wheel base, BMW suspension, and battery lowered center of gravity, it is a pocket rocket around town. But the short wheel base makes it 'rocking horse' on many Interstates at speed. It lacks Autopilot/Full Self Driving driver assistance. So I have two EVs:
    • 2019 Model 3 Standard Range Plus - cheapest to drive, a great cross country car, and mostly well behaved. But at 115,000 miles and 4+ years, I have begun to doubt the "reserve range" claims of early reviewers. I've bought instrumentation to find out but doing the 'forbidden' experiment requires the 'EV spare gas tank.' Furthermore, 'hotel Tesla' lacks off-grid power.
    • 2017 BMW i3-REx - slightly more expensive to drive and manual driving with dumb cruise control, a hoot in traffic. At 56,000 miles, there is about a year of battery warranty left but it looks to have ~27 kWh from the new 28 kWh. A recent benchmark showed 106 mi EV range at 65 mph on a Standard day. Like the Tesla, 'hotel BMW' lacks off-grid power.
    Having two EVs, I can tackle multi-day repairs on one and still have a working EV to get tools, parts, and live normally (well what I call normal.) This reduces my total cost of ownership and provides intellectual amusements for this retired, 73 year old, engineer. <GRINS>
    My EV projects list:
    • Tesla front suspension link - a latent design defect lets rain water drip on the front, upper ball joint. This leads to a squeak that can be temporarily resolved by disconnecting the ball joint and manipulating the residual grease on the joint. But it will come back. So I have a pair of after market links that 'shelter' the ball joint from rain water. Each will require a long day to remove the old links and install the new.
    • "Hotel Tesla and BMW" - rework or replace the passenger seat and rear bench cushions so both have a fully reclined, single bed. I did this with my 2003 Prius gaining not only a place to cat-nap but also handle larger, longer loads. In effect, 2x4 boards from the passenger footwell out the open trunk.
    • Complete Tesla silvered cabin cover - a work in progress for the Tesla, I'm adding additional side cords to handle winds better. The current one reduces the outside and inside temperatures to 5 F in the midday sun. Tenting will be independent as the Tesla is too low to support standup, door tenting.
    • Combined BMW cabin cover and tent - planned, it will achieve Tesla temperature management but also provide a stand-up tent when camping or traveling. Designed for Spring, Summer, and Fall, it supports comfortable camping even in moderate rain.
    • Tesla aerodynamic tuning - underbody air dams, wheel covers, front air inlet covers, removable side mirrors, anti-bloom side camera covers.
    • Tesla steering with self driving spoofing - cut the upper steering section to make it into a yoke. The steering spoof supports hands-free driving.
    • Identify failing sensor - a puzzle with just one mechanic, me.
    • BMW and Tesla trailer wiring - I want a universal solution for both vehicles that uses a trailer electric supply.
    • Transformer trailer - low profile, aerodynamic, crank-up, with no drag motor and regenerative braking. Works from a blizzard to Death Valley. Tented, bug-resistant cooking, out side galley. It might look a lot like a BMW i3-REx.
    That is my short list.
    #20 bwilson4web, Aug 19, 2023
