Help socket stuck in spark plug tube
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Theregulator187, Aug 15, 2023.
  1. Theregulator187
    Theregulator187 Junior Member
    Missouri
    Ivw got a big pair on needle nose pliers and I can grab the head of the spark plug I'm think I need to break the spark plug but again not sure how to go about it the head of the plug is sticking through the top of the socket and I feel like I'm out of options.
  2. Leadfoot J. McCoalroller
    7,766
    7,245
    Pennsylvania
    2018 Prius c
    maybe try a thin metal tube like a bit of brake line. Push both ends of a strong guitar string through it so that you have a loop sticking out one end, and both ends of the string out the other.
    Then you can dip the loop end into the plug well, try to snare the plug connector. Then pull the wire tight from the top end and use that to haul it out.
    Worth a shot anyway.
  3. Mendel Leisk
    40,239
    Is the spark plug completely unscrewed?
  4. ChapmanF
    16,957
    Do we have a way to nominate things for a Redavination Award?
  5. Leadfoot J. McCoalroller
    7,766
    7,245
    Pennsylvania
    2018 Prius c
    Even google didn't help me with this word :(
  6. ChapmanF
    16,957
    I was involved once with someone whose whole family used it, so I picked it up. A private coinage, perhaps, but I wouldn't mind if it spread. It applies to things exactly like guitar strings in brake lines used for stuck-socket plucking.
  7. Leadfoot J. McCoalroller
    7,766
    7,245
    Pennsylvania
    2018 Prius c
    Ah excellent! I was worried it was the sort of thing that got people thrown into volcanoes.
    Thinking through a refinement of the idea: a larger loop might allow getting under the socket itself, not just the connector bulb at the top of the plug. A second (or even a third) wire might provide a better grip.
    And a stainless steel drinking straw might be easier to come up with than a spare bit of brake line.
  8. ChapmanF
    16,957
    For some, I suppose.
    I've got no stainless drinking straws, but a roll or two of brake line, plus other similar metal tubing.
  9. Kenny94945
    Kenny94945 Active Member
    833
    412
    Sausalito
    2016 Prius v wagon
    Well baring Redavination.....
    As asked above by Mendel, Is the spark plug 100% loose/ unscrewed?
    (I guess that could be confirmed by the movement of the tip seen through the stuck socket).
    Those Harbor Freight hemostat pliers or even doctor's hemostats seem like the next choice.
    Apply some penetrating oil between the tube and the stuck socket.
    Maybe even some heat, from a hair dryer/ heat gun tool.
    If I read correctly, gluing a second socket had that second socket also got stuck.....try a smaller diameter socket.
    Could be you are at the point of valve cover removal.
    It has been a week, and a few hours on this removal should be the next step.
    I suggest you get a service manual for this process and you also need some new gaskets.
    Might even check for the availability of replacement tubes.
    I do not know if the tube will "Kamakaszi" with cover removal or how the tube attaches....screw in or press in/ stays with valve cover or stays with the head.
    Good luck, let us know.
    A sad Murphy's Law story.
  10. Theregulator187
    Missouri
    No can't unscrew it
  11. ws309
    ws309 Junior Member
    22
    ventura
    Use a small pipe wrench on the top of the tube and is you can get it to wiggle keep doing that until the tube comes off.
  12. Theregulator187
    Missouri
    Tried jb welding a second socket and that didn't work second socket got stuck too but got it out with an impact wrench tubes are pressed in I tried to get them out because that was the next thing I was going to try and just can't get them to budge. Valve cover gasket is new already. Not sure if service Manuel will have anything about moving the tubes.
  13. Mendel Leisk
    40,239
    so the object is to pull the socket off the plug, and out. Did you try long-reach needle nose pliers? Not sure if it’s possible, but worth a try.
    a really strong magnetic reach tool might do it too.
  14. Theregulator187
    Missouri
    My issues with that is I haven't been able to find new tubes online and I don't want to bend the tube because it is soft and aluminum.
  15. Theregulator187
    Missouri
    Yes I did and magnet isn't strong enough tried a couple different ones.
  16. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Are you able to take a photo down the hole so we can see what we're actually dealing with?
    This is so ridiculous, it seems like we must be missing something obvious. Is the outer diameter of the socket wedged to the tube wall?
    Most plug sockets have a hex at the top. Does yours?
  17. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    That sounds like the root of the problem, I don't think a plug socket was used. That's why it was too short and the spark plug is now poking through the middle of the socket, preventing reengagement of the socket extension into the socket for removal.
  18. Theregulator187
    Missouri
    That is correct
  19. Theregulator187
    Missouri
    It was a short socket grabbed my wrong extension there is some pb blaster in the hole
  20. xliderider
    8,016
    3,198
    Honolulu, HI
    But now the plug and socket are glued together with JB Weld?
