Aluminum Skid Plate
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Jun 9, 2023.
  1. Chicagobob
    Chicagobob Junior Member
    Chicago
    Those CarParts splash shields are much flimsier than the originals. The large one sags quite a bit.
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    405
    2013 Prius Plug-in
    I ended up buying one of those boxes of Toyota clips and plastic locking underbody holder together dohickies and have not needed to replace one since the Steel Engine Splash Shield for the Toyota Prius
    You searched for splash - black_jmyntrn
  3. Chicagobob
    Chicago
    One issue I’ve had with the aluminum skid plate is an annoying resonant buzz at low engine rpm. All bolts are tight, but the buzz persists.
  4. black_jmyntrn
    1,728
    405
    2013 Prius Plug-in
    that's a first I've heard of any noise, I know when I installed mine i precut four squares of sound deadoning matt i had and making a sort of gasket if you call it. I planned on getting some industrial-strength floor mat squares and then cutting them into strips, with some heavy-duty spray adhesive. The plan was to set up my engine bay area to get as close to water tight enclosure effect as I could get.
  5. PriusCamper
    PriusCamper Senior Member
    12,628
    5,104
    Pacific Northwest, USA
    My experiences with cat shields has taught me that when you mount plates like this under the car you need solid metal on metal contact to eliminate noise like that. With the shields in the Gen2 Prius there's a plastic cover on the front of the shield that the car has and if you use that with shield install it has the same dampening as a mount for the edge of a drum skin and will make it amplify certain frequencies. The more solid to metal the plate is mounted without dampening from plastic or other material, the less noise/rattle.
  6. AzusaPrius
    AzusaPrius Senior Member
    2,163
    915
    Zero noise or vibration on my install.
    Just great protection and improved aerodynamics.
    black_jmyntrn likes this.
  7. NoReally
    NoReally New Member
    Provo Utah
    Do you mean there's a problem with the skid plate your selling? You are Prius Overlanding right?
  8. black_jmyntrn
    1,728
    405
    2013 Prius Plug-in
  9. h1ph0panonymous
    257
    36
    What’s wrong with the stock underbelly plastic cover?
    how does it catch air and cause bad aerodynamics?
  10. AzusaPrius
    2,163
    915
    The plastic panel is prone to being torn and damaged, which can cause drag.
    Lose your oil pan door and now you have more drag.
    Not to mention the plastic one is not flat.
    The aluminum skid plate will protect your engine from road hazards.
    One of the good upgrades to do to a prius.
  11. h1ph0panonymous
    257
    36
    how is does aluminum fair in salty snowy roads in the northern states?
    Or would plastic be better for my situation?
    guessing the metal is more the southern off road thing
  12. AzusaPrius
    2,163
    915
    You can always spray it with a coating.
    Better to have a big rock hidden in the snow hit your aluminum skid plate than tear apart your plastic one.
    h1ph0panonymous likes this.
  13. Bill Norton
    Bill Norton Senior Member
    2,143
    733
    MONW, Ks.
    But what about all your other 'signature links/$$'?
    Like how is that water injection system doing?
    Is that a 'bad upgrade' to do to a prius?
    PriusCamper likes this.
  14. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    :rolleyes::ROFLMAO:
  15. AzusaPrius
    2,163
    915
    @Bill Norton
    I think it would be an extreme upgrade not a bad upgrade.
    I needed to wait on that purchase.
    But I couldnt wait on the skid plate purchase because my plastic one tore off and I was losing my fender liners too.
  16. Mendel Leisk
    41,211
    Did you have "professionals" doing your oil changes?
  17. AzusaPrius
    2,163
    915
    No I do my own oil changes.
    I do not trust companies like Jiffy Lube.
    black_jmyntrn and Mendel Leisk like this.
  18. W_Dog
    W_Dog New Member
    SoCal
    To Burebista:
    Is that steel skid plate off another car? If so, which car, year, etc? And did you need to modify it to fit your 2010 prius?
    thanks!
    #58 W_Dog, Jan 26, 2024
  19. burebista
    burebista Active Member
    186
    127
    Romania
    Nope, it's made for Prius 3. I have a link in my previous post with it.
    It fits fine without modification. The only drawback is that I must remove it for oil filter change but my mechanic is now used to do it. :)
