Helper springs for rear tailgate or liftback, hatch.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sleekitwan, Sep 14, 2023.
  1. sleekitwan
    sleekitwan Junior Member
    25
    UK
    Business Edition
    As title. The 2010 model purchased this year 2023, has had a darn heavy tailgate, and new gas struts did not help much. Saw many ‘helper springs’ that are strong, squat things, square-wire and bright colours, meant for machines of various sorts eg presses.
    I experimented, and came up with an inner and outer creation. 2mm spring wire I think the biggest one, the outer is, and it’s just over 100mm long. The inner is around 90mm long and is perhaps 1.2mm wire.
    Outer spring dims: 20mm OD, 2mm wire, 108mm unsprung length, min length 38mm coil-bound.
    I think the spec sheet said it was 3Nmm.
    Inner spring dims: 12mm OD, 1.2mm wire, 90mm unsprung length, min length maybe 30mm coil-bound.
    See pics. They are just about fully coil-bound ie squashed, when the trunk/boot/tailgate is fully closed and locked. The benefit of these thin-wired springs, is they can be 100mm long, and provide spring assistance due to the mechanics of it all, until the hatch or tailgate is almost half-way open, a point at which mine will actually stand without help now.
    It slammed before, when shutting, and was almost too heavy for the better half and offspring to lift up when closed. Now, by my calcs, between 30 to 45 kg is being held by the springs. My 2c worth is the struts are in the wrong location positions ie the anchor points are maybe not optimal. But the car’s tail is huge, and gapes wide as the ocean when open.
    Anyway, this is a highly-rated mod by me, because quite simply it costs about 10 UK pounds, probably cost you less, and we use tailgates almost every time we use the car. The daily-ness of it, gives it a high improvement score! Pics taken, but I have no idea how to upload here, and free storage took a dive some years ago - ah, ‘hosting’ they called it. Take care all. (Hope the server swap goes smoothly.)
  2. StarCaller
    StarCaller Senior Member
    1,275
    726
    Cedar Crest, NM, USA
    no images visible /
  3. black_jmyntrn
    black_jmyntrn Senior Member
    1,721
    402
    2013 Prius Plug-in
    I did the same and ended up going higher in the pounds of pressure now that I use the rear hatch glass for storage.
    sleekitwan likes this.
  4. ChapmanF
    17,739
    Assuming you have not modified your hatch for storage or something like black_jmyntrn, the first question to ponder here is, why might that even be? The hatch is not heavier than it was in 2010, and the car's specified gas struts lift it just fine when they're new.
    Where did you get your new struts?
  5. black_jmyntrn
    1,721
    402
    2013 Prius Plug-in
    my initial install was from when I had no extra weight... since I sleep in the Prius while traveling, one push of the interior button I installed with the bottom of my foot and the hatch opens on its own with only needing a slight nudge! Just having it open on its own is worth its weight in gold
  6. bisco
    51,522
    my 2012 struts work fine in summer, and stick about 3/4 ways up in winter.
    i don't see any reason to do anything but replace them with oem struts
  7. black_jmyntrn
    1,721
    402
    2013 Prius Plug-in
    OEM is just so... basic... generic... non differentiating from any other Prius. I just can't bring myself to replacing anything on this car with OEM other than ... well.. never mind. ha I think only the inverter water pump and abs components I did replace with OEM.
  8. bisco
    51,522
    keep it simple stupid, that's me :p
  9. black_jmyntrn
    1,721
    402
    2013 Prius Plug-in
    you really shouldn't talk down on your self, from my observations you are far from stupid.
  10. sleekitwan
    25
    UK
    Business Edition
    Okay, I was following out of date instructions for pics uploads…here should be the thumbnails of the pics, for you to tap on, and see the full pics. I have to hit the ‘photo’ landscape icon up top and then tap ‘upload a file’ at the bottom of the dialogue box that then appears, get to my ipad photo albums from there. Sorry about that, here they are, nothing amazing. I very much applaud the ‘push-button’ rear opening, that is the safest and best idea, apart from shifting cargo maybe, tapping it, but there’s a bezel and that’s not a criticism.
    Someone asked where I got my rather poor struts from. It’s a place in the UK called ‘SGS engineering’, and they have some not so good stuff, which I think this falls under - I already mentioned it, but my main gripe is, they were specifically bought at twice the price of most struts, to be better. ‘Nitrolift’ they say on them. Nitrogen isn’t what it used to be? ! Thanks for looking.
    StarCaller and bisco like this.
  11. sleekitwan
    25
    UK
    Business Edition
    Ok, pics in my entry now that I added, sorry about that.
    StarCaller likes this.
  12. ChapmanF
    17,739
    How did that price compare, I wonder, to the spec'd struts from Toyota?
  13. ASRDogman
    ASRDogman Senior Member
    7,422
    3,866
    I got mine off ebay. It is hard to close the lid, and almost smacked me in the jaw when
    I opened the lid. I'm extremely happy with them. SOOOOO much better than the 14
    year old one I replaced.
  14. sleekitwan
    25
    UK
    Business Edition
    Compared to genuine Toyota struts for the liftback, based on 85% of parts queries I have had with dealerships, it seems likely to me, the Toyota ones would be costly. Mine were double the price of cheap ones,at £20 each. I sense where you’re going of course. And seeking alternative sources of genuine Toyota parts is a lesson too - I tried to buy from ‘toyotapartsdeal.com’ in the US, a couple of,brake plates for the rear. 6 months later, I have neither the parts nor the money back…Toyotapartsdeal say i need to go to fedex crossborders, fedex head office say fedexcrossborders only talk with actual customers of theirs…ie toyotapartsdeal.
    £132. They delivered it to an address, some porch, in CA. Patently, this is not my UK address, and how ‘crossborders’ would send a parcel to a US address, is unclear to me - why would homeland/domestic US fedex, get invo,ved at all? So toyotapartsdeal, just keeping flipping me, after a dozen emails, they still say go to fedex, and i keep telling them…anyway, I digress.
    Buying genuine parts from non-dealers, hasn’t worked out is the lesson. So I am stuck with dealer prices for Toyota parts, and I wouldn’t even dream of calling to ask the price of rear hatch struts. Maybe I should. Maybe this is that ‘one time’ the dealer is cheaper or comparable, it’s a point.
  15. sleekitwan
    25
    UK
    Business Edition
    Ah - you are in Florida…warm. Mine work when it’s warm. It’s usually not. ! Jealous of warm.
  16. bisco
    51,522
    i think the experience and cost outside the us or n/a can be vastly different when it comes to parts prices.
  17. black_jmyntrn
    1,721
    402
    2013 Prius Plug-in
    thats crazy...
