Here's my NEW 2023 Prius LE (with aftermarket wheels)
Discussion in 'Gen 5 Prius Main Forum' started by Argyros, Sep 14, 2023.
  1. Argyros
    Argyros Active Member
    274
    141
    2023 Prius
    Hey all- finally picked up my Prius! The aftermarket wheels look to me just like the XLE's 19 inchers, although these are 17 inches! Thank you Discount Tire for accommodating me although I was stuck in traffic to get to you for almost an hour! They rocked and did all 4 wheels, balanced and did the TPMS in about 1/2 hour tops!
    Gokhan, daisy555, otatrant and 10 others like this.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    950
    533
    Cow-lee-fornia
    2023 Prius
    Those wheels are using the same sized tires?
    Looks nice!
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    737
    Monument, Colorado USA
    Sweet! Congrats!
    Remember to break her in by driving very conservative the first 1,000 miles and then get the oil changed. (I believe the 23's use 0W-16)
  4. Argyros
    274
    141
    2023 Prius
    Yes, they are the same new Toyo Tires- just picked it up at the dealer and drove directly to Discount Tire to get the wheels installed; the wheels are from VOXX- Lumi Wheels
  5. Argyros
    274
    141
    2023 Prius
    Yes, I'm already obsessed in the first 23 miles I've driven with the Avg. MPG gauge (and yes, I know it's not exactly accurate, thanks to others on this forum)!
    ColoradoBoo likes this.
  6. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    What is the width and offset of your new wheels? I'm considering MSW Type 42 which are 7" width and 45 offset.
  7. Argyros
    274
    141
    2023 Prius
    otatrant and HacksawMark like this.
  8. Argyros
    274
    141
    2023 Prius
    I had purchased center caps aftermarket from eBay, 62 mm, but they ended up to be too big for the opening- I like the silver, clean look of the current Voxx Center Caps, so I think I'll leave it alone and return the eBay ones.
  9. Bob P.
    Bob P. Junior Member
    Western PA
    2023 Prius
    LE AWD-e
    Nice! Excellent choice.
  10. Preebee
    Preebee Senior Member
    867
    769
    Midwest
    2023 Prius
    Are they lighter than the stock LE wheels? If so, might be a small MPG (and performance) increase.
  11. mountaineer
    mountaineer Active Member
    144
    113
    Ontario
    2019 Prius Prime
    Where does the oil change advice come from?
    Tamadrummer88 likes this.
  12. Ragman777
    Ragman777 Junior Member
    22
    25
    San Antonio Texas
    2023 Prius
    LE AWD-e
    Are they 7 inch wide rims?
  13. ColoradoBoo
    1,132
    737
    I've heard that for many years, now. But The Car Care Nut YouTuber, who's a Master Toyota Mechanic, confirms it on his channel...even showed little bits of metal in an oil change on a new car...stuff you don't want floating around in there for any amount of time.
    rpp and mountaineer like this.
  14. Ragman777
    22
    25
    San Antonio Texas
    2023 Prius
    LE AWD-e
    It’ll be interesting to see the mpg with that wire by rim
    it will be interesting to see the MPG with an 8 inch wide rim
  15. Argyros
    274
    141
    2023 Prius
    The dealer had a disclaimer on the paperwork that talked about the 1000 mile break-in period.
  16. Argyros
    274
    141
    2023 Prius
    Not sure how much the black alloys and hubcaps weigh, but the Voxx Lumi s weigh in at 22 lbs a piece. So far, my mileage has been in the mid 50's with the mode on normal.
    Ragman777 and Preebee like this.
  17. Argyros
    274
    141
    2023 Prius
    They are 17x8 wheels
  18. joe1347
    joe1347 Active Member
    669
    44
    AZ
    nice choice to class up the look.
    Argyros likes this.
  19. Argyros
    274
    141
    2023 Prius
    so night and day from the black 'aero' wheels- I was going to give those a chance, but when I saw the standard wheels in person, I knew I made the right decision to get the new wheels. No brainer for $ 600 installed, all 4 wheels.
    Tamadrummer88 and Preebee like this.
  20. Preebee
    867
    769
    Midwest
    2023 Prius
    "Surprisingly, Toyota fitted the Prius LE with 17-inch aluminum alloy wheels, instead of choosing the cheaper option of steelies. While the alloys will most likely remain hidden under the wheel covers for the majority of the vehicle’s lifetime, they reduce the unsprung weight which translates to marginal benefits on fuel economy and ride quality."
    Found this on the web.
    I've inquired about the weight on the LE wheels from a seller online. I'll report back.
