Red Triangle and I can only shift into neutral and park
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Peter Ampudia, Sep 23, 2023.
  1. Peter Ampudia
    Peter Ampudia Junior Member
    Atlanta
    I had meniscus and ACL surgery on September 1st and have only been able to drive my 2007 for very short lengths of distance and time because of my surgery. This past Wednesday, I tried to start my car, and the red triangle turned on. I ran the OBD, and only codes concerning my air conditioner returned. My air conditioner hasn't worked for a long time, so that didn't bother me. I disconnected and reconnected the battery, and I was able to drive it, and I did drive it for 45 minutes. The hybrid battery even charged up to about 80%. However, when I turned off the car in my driveway, I ended up with the same original issue that I could only shift into park and neutral. With a friend's help, I tried to disconnect and reconnect the regular battery and the lithium-ion battery for 25 minutes, but I still have the same issue. I reran the OBD test after I disconnected and reconnected both batteries, and it didn't return any codes. Any suggestions are welcome.
  2. rjparker
    10,083
    6,254
    Possible high voltage leak, maybe with the ac, possible bad inverter or serious hv battery fault. Inverter fail is the only thing that has done that to me. Sometimes a bad 12v battery needs a load test. I bet there are more Techstream codes.
  3. Brian1954
    Brian1954 Senior Member
    2,148
    835
    South Central PA, USA
