Success: Registered TPMS ID For New Tire/Rim
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by tovli, Sep 12, 2023.
  1. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    351
    272
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    After getting a flat in my new 2023 Prius Prime XSE 19" special Prius tire, I successfully plugged that tire to keep me on the road.
    Then I ordered a totally new 195/50R19 Toyo Extensa A/S II from TireRack, and a rim, TPMS valve, and ornament from my local toyota dealer (at a surprising discount for some reason) so that I can use the plugged tire/rim as a full-size, ready to go spare for hurricane escape trips from south Florida.
    The tire came within a few days. The rim/TPMS valve/ornament took about two weeks before the dealer parts department notified me all was in.
    I scheduled a service visit to the dealer to get the new tire mounted on the new rim and balanced. When I arrived I was told "We're not going to charge you for mounting and balance, only the $200 charge for registering the tire pressure monitor."
    I recovered my composure quickly and asked how much is the mount and balance charge, if I register the TPMS myself? The adviser said that would only be $30, but added "only the dealer can register the TPMS IDs".
    I told him leave it to me - "the procedure for me to do it is on page 522 of the 680 page manual".
    They mounted.balanced the new tire/rim and put it on the car. I had them put the plugged tire/rim in the cargo area, and happily left with my new full-size hurricane escape spare.
    Today, I followed the menus and procedure to register the ID and the new tire showed up. I see I need to let a little air out of it.
    ngc4565, mountaineer and otatrant like this.
  2. otatrant
    otatrant Active Member
    293
    183
    San Francisco
    2023 Prius Prime
    XSE Premium
    Using your experience as a guide I installed a new set of wheels and tires with Toyota OEM TPMS valve stems. Paired whole new set very easily just like manual explains. Thanks.
    tovli likes this.
