key fob and RFID wireless theft - of car or possessions ?
Discussion in 'Gen 5 Prius Main Forum' started by GeoJ, Sep 28, 2023.
  1. GeoJ
    GeoJ Active Member
    179
    176
    United States
    2023 Prius Prime
    XSE
    I have read that there is some risk of criminals stealing your car or getting access to a locked car through some technical capture of RFID signals from the key fob. Is this a real issue to be concerned about? I have also read that although this as been a problem, the key fob technology has been somewhat advanced so that it is less of a concern, and in any case the car can't be driven without the actual key fob even if someone was to get it started.
    Curious if anyone here is knowledgeable on this issue, as it relates to 2023 Prius.
  2. roleohibachi
    roleohibachi Junior Member
    Colorado
    2023 Prius
    XLE AWD-e
    Recent techniques are known as RollBack, RollJam, and Rolling-PWN. None had success against Toyota vehicles. The technical threat to our cars is quite low, as a result, because off-the-shelf solutions aren't available to thieves.
    If you use proximity unlock rather than the radio transmission "clicker", the risk is reduced even further, since no replay attack against this mechanism has ever been demonstrated. I believe this feature is limited to certain trims (can someone advise?)
  3. hill
    8,628
  4. roleohibachi
    Colorado
    2023 Prius
    XLE AWD-e
    Sure, a thief, locksmith, or dealer with access to the manufacturer database of keycodes can, of course, create a key. This is not related to fob signal interception.
  5. Argyros
    Argyros Active Member
    274
    141
    2023 Prius
    Do you know if you press the lock and unlock button at the same time and hold, it will deactivate your remote? That way, if your car is close by, and your remote normally tries to 'talk' to your car, it won't be able to unless you're at the car opening it. Eliminates the possibility of having someone scan for your remote and take over access to your Prius. There's videos on this online through YouTube. I don't have to do this luckily, because my garage is about 1000 feet from my remote at night.
    roleohibachi likes this.
  6. aforkosh
    aforkosh Active Member
    412
    270
    Oakland, CA
    2023 Prius
    The appropriate action is to press the Lock button and then push the UNLOCK button twice. You should see the red LED in the corner of the fob flicker 4 times (2 sets of 2). Your fob will now be deactivated. To reactivate it, push the LOCK or UNLOCK button once. All these actions can occur whether you're near the car or many miles away.
    roleohibachi and GeoJ like this.
  7. GeoJ
    GeoJ Active Member
    179
    176
    United States
    2023 Prius Prime
    XSE
    So if you want to do this and keep your car locked, you just do this out of the range the fob would unlock the car?
  8. Argyros
    274
    141
    2023 Prius
    yes.... that will do it! Thank you, aforkosh, for clarifying the keyfob process
