  1. ukulelegeek
    ukulelegeek Active Member
    159
    112
    New tires for the 2010. Goodyear. They ride stiffly, but I guess that's due to them being Low Rolling Resistance tires..
  2. hill
    8,732
    Continental makes some of the very smoothest riding / quietest LRR tires. They have a 1½" inner foam lining. More & more plugin cars on the road have to get quieter - or you start to notice the only remaining noises - coming from either the wind or the tires.
  3. Prius Traveler
    Prius Traveler Junior Member
    17
    Kansas
    Went on a trip via airplane (overseas) and when we came back, the airport police stated to call this number. To make a long story short, our catalytic converter was stolen, perpetrator was apprehended, and we could not get the catalytic converter back as it is being held for evidence. Two weeks later we received our catalytic converter back, I welded it back on to the exhaust pipe, replaced the O2 sensor (wires cut), and replaced the muffler and gaskets while I had it taken apart. A month later, the driver side axle bearing hub was replaced at 643,323 miles for the first time. I did not replace the passenger side axle bearing hub at this time (still the original). I want to see how much longer it last. Currently the car has 644,411 miles and counting................................
    icyrius, Montgomery and douglasjre like this.
  4. douglasjre
    douglasjre Senior Member
    2,147
    711
    Null, NL
    Got pix of out/inside?
    Montgomery likes this.
  5. PriusCamper
    PriusCamper Senior Member
    12,378
    5,019
    Pacific Northwest, USA
    It takes a good 400 to 500 miles of tire wear for the tires to settle down and start working as designed...
  6. ASRDogman
    ASRDogman Senior Member
    7,450
    3,872
    6.5 million miles on the hubs????? Let alone on the whole car??? :eek::rolleyes:
  7. hill
    8,732
    Really? Yikes. Just put on new Michelin crossclimate2's. Winter in the Northwest is approaching fast and I'll probably have less than 200 miles on them when the first snow hits
  8. Prius Traveler
    17
    Kansas
    douglasjre - are you wanting pictures of the removed axle bearing hub?
  9. Prius Traveler
    17
    Kansas
    Regarding my previous post about getting my catalytic converter stolen, when I went to the car and drove it back to pick up the family at the arrival section of the airport, a lot of people were confused. As we drove the Prius back home on the highway, all of us were wearing either earplugs or earbuds, and all other drivers were staring at us, again really confused. Everyone saw a Prius, but what they were hearing was freight train. It was a painful hour and half drive to the house. All is good now and the miles continue to tick away.
    Priipriii likes this.
  10. ChapmanF
    17,783
    Looks more like 0.6 million miles to me.
    PriusCamper likes this.
  11. Coots
    Coots Member
    62
    25
    Hailing from parts unknown, Iowa
    Add an OEM rearview mirror with compass.
    #19291 Coots, Nov 15, 2023
    icyrius, Xterra72, hill and 1 other person like this.
  12. tony_2018
    tony_2018 Member
    227
    66
  13. BK619
    BK619 New Member
    San Diego
    Dirty girl
  14. ASRDogman
    7,450
    3,872
    You need filters.....
  15. hill
    8,732
    JEEEZ - if our turbo woud have experienced even ⅛ of that much filth, it would have shut down & gone into limp mode.
  16. ASRDogman
    7,450
    3,872
    Khezekiah, Grit, Mendel Leisk and 4 others like this.
  17. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    This is still on its original engine? If so, have you ever replaced the head gasket? What other maintenance have you done?
  18. ASRDogman
    7,450
    3,872
    Original motor. Replaced head gasket 43,000 miles ago. Coolant still at the
    same level...
    Joele3, Grit, icyrius and 1 other person like this.
  19. Bohemian Grove
    49
    32
  20. bluhawk
    bluhawk Junior Member
    25
    Torrance, CA
