A little tricky get Prius into netural
Discussion in 'Gen 2 Prius Main Forum' started by FishHawk, Dec 17, 2006.
  1. FishHawk
    FishHawk New Member
    176
    Had my first car wash with the tractor guides and had to put the Prius into netural. A little tricky. Almost couldn't do it. A little scary as if I had it in D I would have hit the car in front of me. Any tips as to how to get it into N from a complete stop? Perhaps I was a little rushed and didn't concentrate on the task at hand.
    I also took off the antenna as recommended . Got a beautiful car wash after all of this.
    FishHawk
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Just hold the shifter in the "N" position for about 1 second, it'll go right in.
  3. john1701a
    john1701a Prius Guru
    12,805
    5,291
    57
    True. Quick doesn't work... which is a darn good thing. I always hated how easy it was to bump a traditional shifter.
    I hadn't even thought that some people wouldn't realize that just waiting a second was required to shift into neutral. That tip will most definitely be added to the User-Guide. Thanks for indirectly pointing out the need.
  4. nicoss
    nicoss New Member
    304
    At my regular car wash they are quite aware of the hybrid peculiarities:
    - Do not turn it off (since that places it in park)
    -Turn off the lights & AC
    -Stick a big blue tag on the driver’s window which indicates that the car is a hybrid and is on.
    They actually hand wash the cars while they roll on the rails.
  5. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    Don't worry, FishHawk, I did the same thing first time I went through a car wash. One thing I've learned - the Prius is NOT a car for those who insist on immediate gratification.
  6. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    I actually backed out of my first car wash! Just waint another second and all is fine.
    <div class='quotetop'>QUOTE(FishHawk @ Dec 17 2006, 08:30 AM) [snapback]363356[/snapback]</div>
  7. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(FishHawk @ Dec 17 2006, 05:30 AM) [snapback]363356[/snapback]</div>
    Glad I wasn't the only one. It did get easier.
    Dave M.
