Anybody know what's causing this sound?
Discussion in 'Gen 2 Prius Main Forum' started by robert Kwasny, Oct 23, 2023.
  1. robert Kwasny
    robert Kwasny Junior Member
    35
    so cal
    2005 Prius 122,000 MI. Soon as I get in the car a rapid ticking sound starts coming from either under the seat or inside the battery pack case. The sound lasts for about 10 seconds stops and then we'll start again. Nothing is turned on in the car it's not in ready mode. I get in first thing in the morning and it starts.
    It's not throwing any codes but I get an intermittent abs warning. Any thoughts would be appreciated.
  2. Tombukt2
    12,901
    2,316
    Probably the accumulator and pump assembly I don't know if you intended to post a sound bite it didn't post
  3. robert Kwasny
    35
    so cal
    Thanks I didn't post a sound bite and I have no idea what that part is but I will look it up
  4. Tombukt2
    12,901
    2,316
    If you stand in front of the car and look at the silver thing that says hybrid synergy drive the inverter right behind it and slightly to the left on a bracket is this big thing called the break actuator accumulator It's the brake pump part of the business It's not the part that your foot deals with that thing clicks makes a racket so on and so forth especially from 150,000 mi on up or somewhere in there or say after 9 years if we're dealing with just time it is time sensitive as well as wear sensitive these electronic parts that is so today these 0809s '07s they're all well over 10 years old so any of these medium wear electronic items like the brake pump are subject to be getting flaky it's just the nature of the electronic part I guess but then again some slip through I've seen some at 430,000 mi with the original brake pump and the original hybrid battery working in operating seemingly fine I don't get a chance to take those vehicles into the mountains and see how bad they'll do I just get to work on them and send them on their way we're pretty much in the flatlands here so we can get away with seemingly quite a bit.
  5. robert Kwasny
    35
    so cal
    What puzzles me is how it could start ticking when I just get in the car. And if the faulty part is in the engine compartment why does the sound come from the rear?
  6. bisco
    51,843
    the brake actuator sounds when you open the drivers door. it's more of a buzzing to me, and sounds like it is under the hood behind the dash, which is where it is.
    a ticking from under what seat? the battery is behind the rear seat
  7. robert Kwasny
    35
    so cal
    Either under the back seat or in the high voltage battery container. Could also be under the car in that area.
  8. Stevewoods
    Stevewoods Senior Member
    659
    1,125
    Seattle, WA
    Yellowjackets!
    Personally, I would try to repo sound as I lied under the car or across the back seat or woth head underhood to narrow down.
    And you have posted this in two separate places. Highly frowned upon
  9. robert Kwasny
    35
    so cal
    Sorry I wasn't aware that I posted in two places. Haven't been on here in a long time must have clicked the wrong button. I will record the sound thank you
  10. bisco
    51,843
    How is the 12v health?
  11. robert Kwasny
    35
    so cal
    #11 robert Kwasny, Oct 23, 2023
  12. robert Kwasny
    35
    so cal
    The Forum won't allow me to upload any of my files. Can somebody please tell me what file extensions are allowed
  13. bisco
    51,843
    It might be broken, idk.
    Can you upload a video?
  14. robert Kwasny
    35
    so cal
    That's the first thing I tried but the file was too large
  15. bisco
    51,843
    Did you try a thumbnail? I don’t think I’ve ever uploaded a video.. some people place them elsewhere, and provide a link
  16. robert Kwasny
    35
    so cal
    Here's a YouTube link
    New 12 volt battery installed. Here is the sound it makes and if you were wondering what that board is I don't have backrests installed. I used the car for work and that board is to just keep things from falling into that crevice.
  17. bisco
    51,843
    i have never heard of anything like it. it sounds like someone is tapping on the board. can you remove it?
    otherwise, maybe get under it or a lift to see if something underneath is rattling
  18. bisco
    51,843
    does it stop when the engine shuts down?
  19. robert Kwasny
    35
    so cal
    As I said before it does it as soon as I get in the car without being in ready mode no ignition on nothing. Then it continues to do it with car running and with break on or in park the noise starts and stops continuously. Not sure if I can hear it when the car is moving I'll have to check today
  20. ChapmanF
    18,073
    Put me down for a brake system issue. A strong hint is the starting when you just get in the car, because that's when the brake pressure pump will start to run (triggered by opening the driver's door) in preparation for driving. In the background of the recording, faintly, I do think I hear a constant buzz that reminds me of what the pump sounds like. The engine isn't running at this point, right?
    If there is some leakage around a hydraulic valve in the brake actuator, the pressure being built up by the pump could be leaking into one of the rear brake lines, giving a fluctuating pressure in that line and wiggling the components at one of the rear brakes. I'm purely speculating here; a mechanics' stethoscope (they're cheap) would tell you if I'm on to something or not.
