Winter tires?
Discussion in 'Gen 5 Prius Main Forum' started by Downrange, May 23, 2023.
  1. Mendel Leisk
    41,234
    Hubcentric is good, might even be Toyota behind the scenes. Try to cobble some sort of centre cap, and/or coat the hubs with some rust preventative; they get groddy pretty fast with road salt.
  2. jeremnyc
    jeremnyc Junior Member
    95
    2023 Prius
    Are these rims able to be acquired with the $150 coupon currently available to Costco members?
  3. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Switched to 17" wheels and winter tires (Michelin XIce). These will be my wheels going forward. Will sell the 19" OEM wheels.
    Tideland Prius and otatrant like this.
  4. Blackat
    Blackat Active Member
    449
    309
    Colorado
    2023 Prius
    Limited AWD-e
    Looks good but why not keep the OEM for summer and not pay to swap out tires every season?
    Bill Norton likes this.
  5. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Personal preference. Primarily road noise and comfort. Storage is a bit of an issue. Plus it's easier to fit four unmounted tires in the back with seats folded down rather than four mounted tires so I won't have to make multiple trips to the tire shop just switch out from winter to summer. Not that much more in cost to mount/remount tires over switch over of wheels. If I had the storage, I would most likely have another set of 17" wheels.
  6. Mendel Leisk
    41,234
    You should be able to fit four mounted tires.
    MPGS-LOL, fuzzy1 and Trollbait like this.
  7. Trollbait
    12,484
    Yeah, the point of a second set of mounted tires is to avoid having to go to a tire shop at all for the swap. A basic hydraulic jack that works for a Prius is not a large expense.
    It's different if a place to do basic maintenance isn't available.
    Bill Norton and Blackat like this.
  8. Mendel Leisk
    41,234
    Yeah, best:
    Two sets of rims, DIY swap
    So-so:
    Two sets of rims, pros do the swap
    Don't go there:
    Pros swapping loose tires on one set of rims, twice yearly
    otatrant likes this.
  9. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I never said I couldn't. Personal preference.
    Been doing this on every vehicle I've owned for the last 20+ years. Never an issue with the local Les Schwab tire store I take my vehicles to. If they mess it up, I'm confident they will make it right.
  10. fuzzy1
    10,387
    One of my reasons for separate rims and at-home swaps is that I can do it on my own schedule. If going to Les Schwab or any other tire shop, it must be done pre-season, before the forecast hints of any need for winter tires. The moment anything shows in the forecasts, the shops have all-day waiting lines.
    I was at dad's place for various farm tasks a couple years ago when his car (for his chauffeurs, he couldn't drive anymore) needed the winter tire swap. Due to the weather forecast, the local Les Schwab was already filled up the first day. We got his car in before cut-off the next day, but still didn't get the car back until a couple hours after usual closing time. At least that shop kept working until all the cars they took in were done. But the front desk had to cut off the queue many hours earlier.
  11. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Yes when making the swap, timing is everything. 8 am when they open seems to be the best time for an appointment.
  12. fuzzy1
    10,387
    ... if one doesn't have to already be somewhere else by then.
    I found that it takes less time to swap them myself at home than to schedule an appointment and adjust other necessary activities around that appointment.
    Blackat and Mendel Leisk like this.
  13. Mendel Leisk
    41,234
    And/or you would like to:
    1. ensure the lug nuts are torqued properly, in sequence
    2. take the time to put a little anti-seize on the hubs
    3. eyeball the brakes
  14. Nntw
    Nntw Active Member
    398
    247
    Toronto
    2023 Prius Prime
    Glad i checked in with my tire shop. they mentioned my 205/60/16s were here and waiting for me.
    They should have the 205/65/16s here by tomorrow instead.
  15. Nntw
    Nntw Active Member
    398
    247
    Toronto
    2023 Prius Prime
  16. Nntw
    Nntw Active Member
    398
    247
    Toronto
    2023 Prius Prime
    So as of 10/31/2023, my Prius Prime has its winter footwear.
    205/65/16 Michelin Xice, on 16" C wheels. Not a lot of clearance to the calipers, but enough.
    Probably would've had tpms if the Toyota parts had been available, but wasn't going to take a chance on aftermarket.
    Thanks to everyone who participated in this thread and helped with this decision.
    otatrant and Mendel Leisk like this.
  17. GeoJ
    GeoJ Active Member
    199
    184
    United States
    2023 Prius Prime
    XSE
    So you find road noise noticeably less with the 17"? Have you been able to notice any other difference in handling or the way it drives? What I am wondering, are the 19" tires purely a cosmetic advantage (if you like them) and all disadvantages when it comes to function?
  18. Mendel Leisk
    41,234
    Why did I expect it to look like your avatar? o_O
    Nntw likes this.
  19. Nntw
    Nntw Active Member
    398
    247
    Toronto
    2023 Prius Prime
    Ah. Well, this is the 'after' (the apocalypse) pic.
  20. Trollbait
    12,484
    It's mostly cosmetic. There are some performance advantages in things like cornering, but likely not a difference to come up on public roads.
    I think tread pattern is big influence to noise.
    HacksawMark likes this.
