2015 Prius w/110k miles - Sock it to me
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusGuy32, Oct 27, 2023.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Fully aware of the EGR circuit issues... not sure if that is still a thing on the 2015's after the changes to the engine Toyota made (pistons/rings, etc)?
    What mileage do ya'll recommend cleaning the EGR? I've changed the transmission fluid around 95k miles, have a dealer app't for coolant changes, anything else I am missing?
  2. Mendel Leisk
    41,316
    100k at the latest, 50k thereafter, like the engine coolant change interval, if you want to synch. Coolant spill can be very controlled though; see second link in my signature.
    every 50k would be optimum.
    Yup.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,231
    824
    Monument, Colorado USA
    A couple things...this is my maintenance schedule:
    Oil/Filter Every 6-months or 5,000 miles
    Air Filter As Needed (check every 6-months)
    Cabin Air Every 12-months (Charcoal)
    Radiator Coolant Every 5-years or 50,000 miles
    Hybrid Coolant Every 5-years or 50,000 miles
    CVT/AT Tranny Every 5-years or 50,000 miles
    Spark Plugs/PCV and PCV Valve Hose/ Radiator Cap / Gas cap Every 10-years/100,000 Miles
    Brake Fluid Flushed Every 4-years/50,000 miles
    Throttle Body Cleaned Every 25,000 Miles
    MAF Sensor Cleaned Every 25,000 Miles
    Tire Rotation Every 5,000 Miles
  4. Mendel Leisk
    41,316
    I’ve finally talked myself into 12 months or 5k miles. Only putting on 3~4K kilometres per year. :unsure:
    ColoradoBoo likes this.
  5. ColoradoBoo
    1,231
    824
    I've wondered if anyone has done a study to compare ICE engines with hybrid's with our numerous start/stop cycles...if that shortens the life of the engine by causing extra wear-and-tear. If it wasn't a Toyota engine, I'd be changing the oil every 3,000 miles (which is what I do for my kids non-Toyota vehicles.) I know the Ford engines that have the stop/start technology don't last nearly as long at Toyota's.
