Replacing underbody shields
Discussion in 'Tesla' started by bwilson4web, Nov 7, 2023.
  1. bwilson4web
    16,123
    There are three panels: (1) under front fender cover; (2) just behind front, and; (3) rear bumper and drive area. The battery is behind the middle and before the rear. Of the three panels, the middle one was in saddest state:
    The original fragments on the left was some sort of plastic backed felt. The replacement part on the right is a full injection molded part. The forward part of this middle panel bolts onto the rear of the front shield.
    The washer of one bolt bent up so it almost became a 'wing headed bolt.' I lost a lot of time, at least an hour, trying to get it unbolted. Eventually I left it and just tie wrapped the left front and right front bolt hols as the auto shop was going to close soon.
    I have three, leftover 10 mm bolt-washers and will use two tomorrow when I replace the forward underbody shield. The replacement part lost two former wing corners out toward on the rear by the battery. When fixing a 2019 Model 3 with parts in 2023, 'some creative assembly is required.'
    There is always a tradeoff between a specific fit part and two pieces that assemble to handle both Model 3 and Model Y. In my case, I will use exceptionally heavy duty, duct tape along the bolted joint between the front and middle panels to minimize drag and splash water incursion. I am also OK with replacing some 10 mm bolts with plastic tie-wraps. They are strong, light weight, and easily replaced without a socket wrench.
    On my 'to do' list, I have 3d party, lighter, stronger, drip-water proof, front links to replace the OEM ones. I may do them before repairing the front, underbody shield. I had already massaged the grease fitting on the passenger side link to eliminate the body squeak but on the first freezing morning I may have heard the driver side.
    #1 bwilson4web, Nov 7, 2023
  2. Mendel Leisk
    40,983
    Our daughters 3 had a large under panel tear, needing replacement. From going over snow. Some sorta fibrous, paper-like material.
    bwilson4web likes this.
  3. bisco
    51,533
    I’ve had good luck with gorilla tape
  4. sylvaing
    sylvaing Senior Member
    1,210
    514
    5" is the maximum snow the Model 3 will go over before becoming a plow itself
