I don't drive much. How can I keep my 2013 Prius c 12v battery in good shape?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by RTW, Nov 9, 2023.
  1. RTW
    RTW Junior Member
    31
    Portland Oregon USA
    Keeping in mind that the 12v battery is under the back seat, and not easy to access, and AFAIK there is no way to charge/jump the battery in this model/year from under the hood or the trunk, so a trickle charger seems unrealistic.
  2. Leadfoot J. McCoalroller
    8,054
    7,537
    Pennsylvania
    2018 Prius c
    2013-2019 Prius c cars have an easy-access charge point under the hood, in the drivers' side fuse panel.
  3. Leadfoot J. McCoalroller
    8,054
    7,537
    Pennsylvania
    2018 Prius c
  4. bisco
    51,781
    what year did they come out? i thought they forgot the jump point on the early models
  5. Leadfoot J. McCoalroller
    8,054
    7,537
    Pennsylvania
    2018 Prius c
    Yeah, the 2012 has nothing. 2013 and later are good.
  6. bisco
    51,781
    you can run permanent charge leads from the battery, making connection to a maintainer a breeze.
  7. bisco
    51,781
    or just use the jump point as ljm says above
  8. RTW
    RTW Junior Member
    31
    Portland Oregon USA
    This does not exist on my car. My 2013 c was made before the feature was included. See this thread: jump terminals on a 2013 prius c (under the hood) There or Not | PriusChat
    This sounds nice, but way too complicated for me.
    #8 RTW, Nov 10, 2023
  9. RTW
    RTW Junior Member
    31
    Portland Oregon USA
    As a follow up: I do drive at least once a week, maybe 10 minutes to store and 10 back. I guess I was wondering if driving on the highway once a [?] for [?] minutes would keep the battery nice and charged?
  10. Mendel Leisk
    41,205
    Maybe hire a professional to wire it then; seems like the optimum solution.
    CTEK chargers for one typically come with a quick-connect harness. You can connect at the under-the-hood fuse box. That’s my setup: to connect the charger I pop the hood and raise it, plug charger into the quick-connect, plug charger into wall, lower hood gently, not latched.
    Ours is garage parked, makes it secure. I don’t think you’d want an exposed quick-connect if parked outside; someone could get clever and short it out. But there should be discrete/secure methods.
  11. Leadfoot J. McCoalroller
    8,054
    7,537
    Pennsylvania
    2018 Prius c
    Best answer I can give: 25 minutes in READY mode. Up to you whether the car moves or not. In a hybrid, 12v charging is disassociated from engine RPMs, so don't feel the need to take a cruise.
  12. bisco
    51,781
    Unfortunately, no one can tell you how much you have to drive to keep it charged.
    Every battery has a different level of health, and you have to monitor it to know what is working and what isn’t.
    did you ever look in the fuse box for the positive terminal?
  13. RTW
    RTW Junior Member
    31
    Portland Oregon USA
    Yes. As I mentioned above, unfortunately, mine doesn't have that feature. They started adding it after my car was made. :/
    But I've been researching how to use a Battery Tender, and think I'll give that a go.
  14. RTW
    RTW Junior Member
    31
    Portland Oregon USA
    I'm curious about this... how does it charge the battery if the engine isn't running?
  15. Leadfoot J. McCoalroller
    8,054
    7,537
    Pennsylvania
    2018 Prius c
    The 12v battery is charged by the DC-DC converter, which itself is driven by the hybrid battery bus. When the car is in READY mode, this bus is energized. The hybrid ECU controls whether the engine should run or not in response to total energy demand. The DC-DC converter is just one of many potential loads.
  16. Mendel Leisk
    41,205
    Your fuse box doesn’t have the clamp-on jump start point, but it will have a 12 volt positive lead feeding into fuse box. I don’t have a c, can’t provide a definitive picture, but it will likely be an extra heavy cable, bolted down with a pigtail connector, and might have a plastic cover.
    This is a good location to connect the positive lead of a charger’s quick-connect wire. It’s negative lead can be connected to bare metal of engine or body. Look for hold-down bolt in vicinity, or an unused threaded hole, if you can drum up a compatible metric bolt.
    Again, if you have to you have to, but it is a little absurd to be driving significant percent, just to maintain 12 volt.
  17. RTW
    RTW Junior Member
    31
    Portland Oregon USA
    Is there an easy/simple way to monitor the battery over time without having to disconnect anything under the hood or access the battery itself (which requires removing a panel under the back seat, and removing bolts, etc.).
  18. Mendel Leisk
    41,205
    Electronic load testers typically require direct connection to the battery posts. Shortsighted design decision by Toyota.
  19. Leadfoot J. McCoalroller
    8,054
    7,537
    Pennsylvania
    2018 Prius c
    I don't know of one. Probably the best thing you could do is pay a pro to install such a thing- either a meter or a quick-disconnect where you'd be able to attach a meter.
  20. bisco
    51,781
    They make meters that plug into the 12v accessory outlet.
    The car should be on but not ready.
    There is a load on the battery when on, but if you watch it over time, it might be helpful in forecasting a coming problem
