Red Triangle P3000 etc
Discussion in 'Gen 2 Prius Main Forum' started by mjaajm, Nov 7, 2023.
  1. mjaajm
    mjaajm Junior Member
    Michigan
    287k on the car. Replaced bad cells at 250k.
    Got the red triangle last Thursday. Towed home. Ran 3 cycles of reconditioning with Prolong. Car ran great for about 5 miles and the triangle was back.
    Towed back home. Ran Dr Prius on it - see attachment.
    Thoughts on Greenbean battery? They suggest replacing the 12v - necessary? Time to call it a day?
      File size:
      218 KB
    51,900
    get a free 12v load test at auto zone.
    maybe you need to replace some cells?
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,045
    1,969
    NJ-USA
    What code triggered the "master caution light" "(RToD)?
    If a failed battery module set a P3000 - PA080, then a cell in that module is likely DEAD and you can't "bring it back" with any type of conditioning.
