2013 Prius 4 with blown HG.. $4800, worth it?
Discussion in 'Gen 3 Prius Main Forum' started by 462disco, Dec 19, 2023.
  1. 462disco
    462disco Junior Member
    32
    Socal
    Looking at a 2013 Prius 4 with a blown HG for $4800. Seller states p0300, P0302, P0304 codes, with misfiring & rattle. Confirmed coolant in cylinder 2 from Toyota.
    142k miles, clean title. Checking it out tomorrow but seems to be in good condition. Is it worth $4800, or should I negotiate lower?
  2. Tombukt2
    12,921
    2,321
    Check the door panels and armrests especially the fronts see if they're caving in when you put your arm on them That's a major issue for me Believe it or not finding good door panels is almost impossible for this model they didn't make a base model with all plastic door panels they're all the same problem. And any of those other things that tend to fall apart on the generation 3 look at the seat bolster on the driver's outer seat back knowing what I know now about the engine and whatnot No I would not do it was easy engine is the problem.
  3. bisco
    51,873
    get an engine and brake actuator replacement cost, then see if it's worth it.
  4. JC91006
    JC91006 Senior Member
    16,766
    8,563
    The car seems to be worth it if you can perform the work yourself. There are other maintenance items you would need to do as this car approaches 150k miles. You really need to get a list of maintenance items already performed, so you can better assess the total cost later. At 150k miles, it's almost like rebuilding the entire drivetrain.
    Repairs needed soon
    1. water pump
    2. brake booster
    3. hybrid battery
    4. head gasket
    5. shocks/struts
    6. brakes
    7. change all fluids
    8. exterior paint
    9. and more
    so you see the list is a big list for cars this mileage. If you decide you are going to pass on it, please let me know so I can check it out LOL.
  5. 462disco
    32
    Socal
    Thanks for the tips everyone!
