12v battery keeps dieing and after jumping 3 or 4 times car stopped moving while driving.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Cefusok, Jan 1, 2024.
Tags:
  1. Cefusok
    Cefusok New Member
    Bakersfield, california
    Hello my 2015 prius has 240k miles just stopped accelerating on me while driving. My 12v battery died a month or two ago had left the lights on. I jumped it it was fine then dome light was left on 3 or 4 weeks ago and jumped it again it was fine then a couple weeks ago my water pump or thermostat stuck and has been causing overheating issues but when driving with heater on max have not problems but my 12v battery dies last night and again jumped it ran fine to work then got off and came out to it dead again got a jump and drove about 1 mile and the car lost all power triangle od death light came on check engine light and the traction and abs light s came on pulled over and turned off car then when. Tried to turn it back on git a aux battery low message and the car wouldn't turn until slowly lost all power to display and lights git another ju.p only for it to happen again about half a mile down the road got car towed to my house and when hooked up to a battery jumper tool it started right up and drove into my garage no problem. Is this all just from my aux battery being unable to hold a charge?
  2. PriusCamper
    PriusCamper Senior Member
    12,688
    5,134
    Pacific Northwest, USA
    Perhaps your latest problem isn't directly related to your 12v. Perhaps because you kept ignoring your car problems you might now have bigger problems. Better to fix stuff right away than ignore it.
    Specific to 12v, a Prius doesn't have the ability to fully recharge a 12v battery after a jumpstart unless you drive it for 15 hours without turning it off. And you may luck out and once you get a new 12v or a fully charged 12v that tests out as normal you'll be ok.
    But more likely your car's dash lights means it's stored error codes that point to additional problems. Any auto parts store will read your error codes for free, as well as test your battery.
  3. Brian1954
    Brian1954 Senior Member
    2,148
    835
    South Central PA, USA
    The first thing to do is replace the 12v battery and then check for trouble codes with an OBD2 scan tool.
    The second thing you should do is replace the engine water pump ASAP.
    #3 Brian1954, Jan 1, 2024
  4. Cefusok
    Cefusok New Member
    I have an obd2 and the only code it throws is the p261b or whatever the water pump/ thermostat code is and that only thing in permanent, pending, and normal code sections of the obd2. And only reason it hasn't been fixed yet is because I haven't had the money but still had to get back and forth to work each day as this is my only vehicle at the moment.
  5. bisco
    51,843
    so the answer is yes, and you'll be all set once you get the money for repairs
