Lithium conversion
Discussion in 'Gen 3 Prius Accessories and Modifications' started by risk, Jan 16, 2024.
  1. risk
    risk New Member
    I see a supplier advertising lithium replacement cells with same form as stock. About $2,200. I will assume the BMS can cope with different chemistry so this mod seems an acceptable solution.
    I see junk yards battery packs "2016-2018 LITHIUM-ION G9280-47150".
    Understanding this is type 4 and suppose the form of the cells are different than the earlier ones but is it feasible to swap the pack? I'm prepared to deal with back size and mounting differences. What are the electrical considerations? Plug connectors are easy differences to adapt to.
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,691
    392
    2013 Prius Plug-in
    post the link so we can see...
  3. PriusCamper
    PriusCamper Senior Member
    11,982
    4,872
    Pacific Northwest, USA
    Please give us more details? There are some Gen3 with OEM Lithium, but not very many of them... It's highly unlikely these battery cells are different than OEM and you'd likely need the Toyota BMS for Lithium to make use of these cells.
  4. black_jmyntrn
    1,691
    392
    2013 Prius Plug-in
    The post is too vague... need more details to see what's up with them to give you a definitive answer... but you know you could go to Aliexpress and buy cells on that site to make one? To reach my 50kWh goal I'm considering a form of it but I am trying to get a bz4x battery and use those higher capacities smaller sized cells..
    https://black.jmyntrn.com/2024/01/16/diy-hybrid-high-voltage-hv-battery-with-capacity-increase/
  5. Xeico
    Xeico Member
    53
    45
    Folsom
    douglasjre likes this.
  6. douglasjre
    douglasjre Senior Member
    2,090
    698
    Null, NL
    Know what happens when u ASSume things?
    Brian1954 likes this.
  7. black_jmyntrn
    1,691
    392
    2013 Prius Plug-in
    are you sure?
    New cell (in use since 2020)
    • Manufacturer: Panasonic
    • Capacity: 51 Ah
    • Nominal voltage: 3,7 V
    • Energy: 188,7 Wh
    • Form factor: PHEV2
    • Chemistry: NCM 622
  8. black_jmyntrn
    1,691
    392
    2013 Prius Plug-in
    yep! you end up finding out those on this forum who think they know and talk like they know... really don't know...
    uck around and find out!
    Danno5060 likes this.
  9. Xeico
    Xeico Member
    53
    45
    Folsom
    Hi.
    I'm 100% sure. You gave me information about the plugin.
    Standard Prius with lithium battery has the Panasonic 3.7V 4.6Ah.
    The problem is not in the cells, but in their number, believe me, a standard lithium battery will not work instead a nickel one.
    Grit likes this.
  10. black_jmyntrn
    1,691
    392
    2013 Prius Plug-in
    define standard lithium battery...
  11. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
  12. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    Agree. A standard one don’t cone with a cold temp cut off sensor either.
