2006 prius engine mystery
Discussion in 'Gen 2 Prius Main Forum' started by aradia7572, Jan 14, 2024.
  1. aradia7572
    aradia7572 Junior Member
    sc
    Hi all, I have a 2006 toyota prius with 266,000 miles on it. It has been having some weird issues. It will crank, the engine will run and charge the battery bank to about 5 bars and then the engine will cut off, then if I press the accelerator the engine will not run, when the batteries deplete back down the engine will run but when I put my foot on the gas the engine will not engage. Also when the engine does run there is an awful loud knocking noise coming from the engine at idle but when I give it gas the knocking sound disappears. This all happens in park. When I drive, it will eventually shut off and stop all together and not run at all. Any answers will be appreciated.
  2. Tombukt2
    12,900
    2,316
    Can you make a video maybe with the hood up and somebody else stepping and not stepping and doing whatever and the noise this actually is kind of more rare for the generation 2. If it was a gen 3 you'd be right on schedule but it's not. Any code stored in the eprom OBD2 stored codes any of that No lights on the dash?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Where are you in SC?
  4. Tombukt2
    12,900
    2,316
    Looks like she might be right around the corner
  5. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    If she's in the Columbia, Irmo or Lexington areas, she has no idea how lucky she is! I do a lot of freebie help.
    Outside that area, but reasonable distance, could still be pretty lucky.....
    Near the state lines....maybe not so lucky....unless it happens to time well with a trip to the Charlotte or Augusta Pull-a-Parts.
    Guess I'll make sure my laptop is charged up just in case....
    Tombukt2 likes this.
  6. aradia7572
    sc
    Can't make a video at the moment, the car has been parked and we have to take the battery out of our other car to put in the Prius so that's a thing.
    The 12 volt battery had gone bad in the Prius so the Prius battery does not work. Do you think the 12 volt battery going bad could have something to do with it?
    Sorry can't make a video of it right now, we have to take the battery out of our running car to put in it to power it up.
    When we power on the car initially the engine will run until the battery charges to 5 bars and then it will shut off, when the battery depletes but the engine will not start up to charge them back up, even if we press the accelerator the engine will not start back up. The engine, when it is running, will knock loudly at idle but when you press the accelerator it will diminish a lot. This is all while sitting in park.
    If we try to drive it , it will only go until the battery depletes and then it shuts off completely.
    Lights in the dash lit up are: the check engine light, tsc light, abs light, and the big red triangle light.
    Haven't had an opportunity to check for codes.
    This car has been sitting for a couple of years because instead of spending a lot of money to try and fix it we just got a used Toyota Avalon at a good price instead. We were just trying to get an idea of what it might could be so we will know if it would be worth it to try to repair it. Thanks for your response!
  7. aradia7572
    sc
    The Pee Dee area
  8. bisco
    51,840
    you need a good 12v to make the car 'ready'
  9. Brian1954
    Brian1954 Senior Member
    2,138
    828
    South Central PA, USA
    Reading the trouble codes should be the first thing that you do!
  10. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    I'm thinking this is a combination of things. The car has sat for a couple years=the HV battery is probably experiencing a few depleted modules. Every time the 12v battery is NFG, the car ecus probably reset to default values, giving an indication of 4-5 blue bars on the HV battery indicator, which would rapidly drop to purple or nothing or even likely not be able to start the engine again. Then the 12v dies and everything defaults again, making it show blue bars again. Would be interesting to connect techstream to see the overall health.
  11. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Close to Darlington?
  12. aradia7572
    sc
    We have no way to read the codes. We do not have a code reader.
  13. aradia7572
    sc
    About 25 miles away in Dillon County
  14. aradia7572
    sc
    This was the problem we were having with the car before we parked it. Had not been having any problems with it then one day out of the blue it did all this. I really loved that car too!
    We have read that it could be the 12v battery but we don't really have the expertise to work on a high voltage car lol
  15. aradia7572
    sc
    We had read that the problems that made us park it in the first place could have something to do with the 12v battery. I know it died shortly after parking it and would not charge back up. Our problem is that the battery that goes in it is about 250 dollars and we haven't been able to afford to buy one to test that theory out, plus if the battery is not the problem we cannot return it because of their store policy so we would just be out 250 if that wasn't the problem.
  16. bisco
    51,840
    it's a conundrum, i don't blame you. you could put in any good 12v battery temporarily, just to eliminate that as a problem.
