UltraGauge MX v1.4
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 462disco, Jan 18, 2024.
  1. 462disco
    462disco Junior Member
    32
    Socal
    Didn't see a recent thread in the last few years, so decided to create a new one.
    Picked up an UltraGauge MX v1.4, with gen 3 specific programming. In addition to all the standard OBD2 gauges, it supports a few extra ones including battery SOC, Amps, battery intake temp, etc. Some parameters are frivolous, but some are definitely useful.
    Just installed mine and have not played with it much, but it's a nifty little tool. Going to set mine up to monitor coolant temp, RPM, oil temps, and maybe a few more.
    Gen 3 specific parameters, and UG mounted below.
  2. Brian1954
    Brian1954 Senior Member
    2,148
    832
    South Central PA, USA
    A Gen 3 Prius does not have an oil temperature sensor, so you can not display it.
    FYI, the car also does not have an oil pressure sensor.
    #2 Brian1954, Jan 18, 2024
    462disco likes this.
  3. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    405
    2013 Prius Plug-in
    Im curious if it'll read TPMS PSI of each tire like inTechstream or using my OBD2 dongle.
  4. ASRDogman
    ASRDogman Senior Member
    7,542
    3,895
    ??? Then what is that oil pressure switch that leaks on the rear passenger side of the
    engine? It's just above or to the side of the timing chain tensioner and looks like there
    is an oil passage there. How does the computer know if you have oil presser or not?
  5. Mendel Leisk
    41,327
    And when the oil warning light comes on, I believe that’s due to low oil pressure?
  6. Brian1954
    2,148
    832
    I should have said that the car does not have an oil pressure transducer, which transmits the oil pressure to the ECM. It does have the oil pressure switch, which will send a signal to the ECM for low oil pressure. Sorry for the confusion.
    #6 Brian1954, Jan 19, 2024
    ASRDogman and Mendel Leisk like this.
  7. ASRDogman
    7,542
    3,895
    I believe I missread that. You said "oil Temerature" not "oil Pressure"..... Sorry...
  8. Brian1954
    2,148
    832
    In the second sentence, I did say oil pressure. So you did not missread what I wrote.
    ASRDogman likes this.
  9. AzusaPrius
    AzusaPrius Senior Member
    2,172
    915
    How fast was the shipping, did they respond quickly?
    Their website seems very dated and there is no contact information.
    What payment options do they take?
    Any update on your use of this product?
  10. AzusaPrius
    2,172
    915
  11. 462disco
    32
    Socal
    You may be able to. The MX version states you can program multiple gauges in the unit, you just have to have the manufacturer code to do it. Apparently Scangauge XGauge parameters can be made to work in the UG, and their list for the Gen 3 specific is pretty big. » TOYOTA – LEXUS – SCION Scroll about 2/3 down. Listed manufacturer codes include traction battery temp, inverter coolant temp, tire pressures and tire temps (I believe the factory sensors support this but have not confirmed).
    UG doesn't do much advertising, it's pretty much all word of mouth. There's a few platforms that the UG is popular with - a bunch of Land Cruiser and Tacoma guys run these.
    Payment was via PayPal, shipped out 2 days after I purchased via USPS. Going to be playing with it more tomorrow and trying to program those extra parameters in.. stay tuned.
  12. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    The distance to empty display on these and gallons in tank doesn't seem to be accurate at all on mine. Hybrid Assistant APP actually is pretty good with those.
