2010 Prius WONT MOVE! HELP!
Discussion in 'Gen 3 Prius Main Forum' started by Chris626, Jan 28, 2024.
  1. Chris626
    Chris626 Junior Member
    25
    Ca
    UPDATE:
    AND THE ANSWER IS……. BROKEN FRONT AXLE
    bisco, djasonw and Mr. F like this.
  2. ChapmanF
    16,966
    Ah ... I guess that could go with a noise even when the car isn't moving, because the slight torque through the transmission would spin the axle stub around, without the wheel restraining it.
    PriusCamper and Chris626 like this.
  3. JC91006
    JC91006 Senior Member
    16,639
    8,495
    Did the grease leak out of there? Anyways, glad it wasn't a transaxle issue
    Chris626 likes this.
  4. PriusCamper
    PriusCamper Senior Member
    11,869
    4,814
    Pacific Northwest, USA
    Thanks for coming back to let us know, peope don't do that often enough on here. And of all the potential repair costs for the symptoms you had this one is probably one of the least expensive ones.
    Johnny Cakes and Chris626 like this.
  5. Chris626
    25
    Ca
    I didn’t see any leakage or oil anywhere below the car
  6. Chris626
    25
    Ca
    Definitely. I can’t be the first to have had this issue but it was definitely concerning. The dealer wants 1100 to fix it but I’m calling the indie shops lol
  7. ChapmanF
    16,966
    Just driving down the road and your axle breaks? I certainly don't recall any prior report of such a thing here.
    Somebody's gotta be first ....
  8. JC91006
    16,639
    8,495
    did the dealer share any pictures with you? I'm curious where it broke
  9. Mendel Leisk
    40,245
    Which side? Owned since new? Curb encounter in past?
    was the EGR cleaned, say in conjunction with engine rebuild?
  10. Chris626
    25
    Ca
    Yeah I was like… the axle? lol But they said it wasn’t uncommon
  11. Chris626
    25
    Ca
    They actually did not, I’ll look at the report to see which side it was. I believe it was drivers side just based off of the symptoms
  12. Chris626
    25
    Ca
    It was drivers side. They recommended EGR
  13. bisco
    50,821
    nice call
    Chris626 and CR94 like this.
  14. CR94
    CR94 Senior Member
    2,658
    1,147
    Northwestern S.C.
    Yes. The only plausible call, considering the symptoms described.
