2010 Prius stalls while driving
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JVCORD, Jan 27, 2024.
  1. JVCORD
    JVCORD Junior Member
    North Carolina
    Greetings. My 2010 Prius Gen III has stalled at least six times in the last year. By "stalls", I mean I give it gas, but the car does not accelerate. I believe it is stalling primarily in hot weather when the A/C is on. It does NOT give any codes or dash warning lights. I have driven with a code reader connected, but after it stalls, I still don't get any codes. It stalled at 65mph on a highway, several times in bumper to bumper traffic, and twice as I was creeping up to an intersection very slowly. Once it stalls, I turn it off, then on again, and it starts with no problem. It runs fine for several weeks/months, then stalls again. I cleaned the MFS, but that didn't help.
    When I put the car in ready and check the inverter coolant reservoir, I see the fluid level is flat, but goes up and down slightly. Is that normal, or should it be bubbling/churning? Would a bad inverter coolant pump cause stalling? Any other possibilities? I thought I read somewhere that there is a part inside the inverter that can overheat and cause stalling? Thoughts on that?
    Any help would be greatly appreciated.
    John
    50,849
    I think you should see some turbulence.
    How many miles on her?
  3. JVCORD
    North Carolina
    It has 198K, however, I sold the car as is. Thanks.
  4. Mendel Leisk
    40,284
    Probably for the best; that’s about when the head gaskets go.
    Can you clarify?
    #4 Mendel Leisk, Jan 31, 2024
  5. ETC(SS)
    6,851
