SE add footwell lights from higher trims
Discussion in 'Gen 5 Prius Accessories and Modifications' started by purplePriii, Dec 12, 2023.
  1. purplePriii
    purplePriii Active Member
    273
    119
    I'm trying to add a few options from the SE model I have that other trims have. One of them is the footwell lights. While not neccesairly something that gets spotted right away, it's a nice addition. It's also cheap to purchase from Toyota directly for $13 a pop or $10 from Aliexpress or the likes for a pair.
    I'll try to add the Toyota part number later.
    For the install, there should be one in on the driver side and one on the passenger side. The wires and everything else you might need is already present in the car, you just need the LED! There is only one way to insert the LED.
    Driver's Side:
    From the driver's side, you need to access the bottom panel. Here you can see the driver's side with the connector for the footwell lights.
    IMG-4643 hosted at ImgBB — ImgBB
    There's 2 screws you'll need to undo and then about 2 plastic clips you can unlock and the plastic panel will fall down. There you'll see a white connector clipped into the plastic panel. You can just press the tab on it and push it out the other way to get it out.
    Tabs look like this:
    IMG-4647 hosted at ImgBB — ImgBB
    You connect it to the LED.
    A little bit to the side of where the connector was plugged into the plastic panel, you'll see a slightly bigger hole in the plastic to insert your now plugged in LED. It should click into place. Now that you're done, just click back your panel and put the two screws back in and you're done!
    Light set into it's place looks like this:
    IMG-4644 hosted at ImgBB — ImgBB
    The little square block on the left of the LED is where the connector rests in the SE.
    Passenger's side:
    This side has no screws. Only 3 tabs in the front and when you set it back have to make sure to set it the back properly.
    Undo the 3 front tabs and you will find the same connector for the LED in its own square. Pop it out like the driver's side and connect it to your LED.
    Here the LED needs to be set and twisted into place:
    IMG-4649 hosted at ImgBB — ImgBB
    Set in place:
    IMG-4650 hosted at ImgBB — ImgBB
    If you pull it too much when attached the light will pop out at times. Just set it back and make sure you have enough slack with the cable.
    When plugged in, make sure to have the back tabs in their holders as in the back of this picture:
    IMG-4651 hosted at ImgBB — ImgBB
    Click back in your 3 tabs in the front and you are done!
    They turn on and off automatically when you open the door. It's a super simple process and I just added the pictures in case anyone was hesitant. Hopefully they stay up as it seems picture upload is still down for this website.
    swisshurb, kenmce, otatrant and 5 others like this.
  2. wrtboy168
    wrtboy168 Junior Member
    70
    27
    Northern California, USA
    2024 Prius
    @purplePriii , i have the le trim and i can locate the holes on the bottom panels where the footwell led assemblies are retained in place. what i'm uncertain of is where will the led gets its power when the let trim may not be pre-wired for footwell lighting. i surmise the le trim must be missing the footwell wiring harnesses and where will they be plugged in? any insights is appreciated.
  3. N79PT
    N79PT Junior Member
    37
    Sonoma County
    2024 Prius Prime
    SE
    I suggest you reread the initial post more carefully. It’s pretty clear and steps you through the process in a very logical way to do the entire installation.
  4. purplePriii
    273
    119
    My bad, the LE does not have the harness indeed. I recently saw an FB post about it and tracked it down for you as the person had an LE and wanted to make it work regardless (I bolded the does not in case someone looks it up one day).
    It's in the "Prius 5th Generation 2023+" FB group if you search for Footwell. There's a couple pictures if you want to check it out.
    It seems around the glovebox area you might have a spot you can use. I am not sure if you'll get the dimming function like the original. I'm supposed to do something to the car this weekend so if I get a chance I can try seeing where the SE footwell connectors attach to and see if you could do something similar in the LE.
    wrtboy168 likes this.
  5. wrtboy168
    70
    27
    2024 Prius
    thanks @purplePriii for the sanity check. i couldn't find any wiring harness for the foot well led after removing the cowl hence came to the conclusion the le trim must not have been pre-wired for the foot well lights.
  6. Hammersmith
    Hammersmith Senior Member
    1,960
    1,964
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    This is probably more than anyone here wants, but Toyota Japan does make a kit for adding footwell lights to all seats. One kit is for only the rear seats(for cars that already have lights in the front), and one kit is for both front and rear. Biggest problems are the cost(medium terrible - $100-150), and the (only in) Japanese instructions(more terrible - and you also need to flip some of the instructions since the kit is made for a RHD car). I've got the back seat version but haven't installed them yet.
    0852B-47080 - rear seat version
    0852B-47090 - four seat version
    If you decide to get either of these, you'll have to order through something like Yahoo! Japan, or an importer like JP-CarParts or Impex Japan.
    wrtboy168 and otatrant like this.
  7. Zeromus
    Zeromus Active Member
    494
    257
    Ottawa Canada
    2024 Prius Prime
    SE
    I'm gonna follow your journey because you're doing things I'd be interested in doing with lights, and it really seems like the Canadian SE model is easier to get some of these small upgrades on than the US LE model.
    After work or at lunch Ill read in more detail but if the lights are super cheap and easy to install, I may as well go for it!
  8. Lantaral
    Lantaral Member
    66
    30
    US
    2024 Prius
    If the light is shunted from the glove box light, wouldn't the footlights only light when the glove box is opened?
  9. Lantaral
    Lantaral Member
    66
    30
    US
    2024 Prius
    $88 & $101 @ Impex, plus about $20 shipping.
    Are the installation guides online?
  10. wrtboy168
    70
    27
    2024 Prius
    the glove box illumination should have its own switch to turn on when the glove box door is opened. i think the foot well lights just stay lit the whole time.
  11. Lantaral
    Lantaral Member
    66
    30
    US
    2024 Prius
    In the trims that ship with footwell lighting, are they continuously on?
  12. wrtboy168
    70
    27
    2024 Prius
    sorry i wasn't clear in my earlier response. the oem toyota harness should not be tapping the foot well lights from the glove compartment illumination. @purplePriii mentioned he'll try to find out how the oem foot well harnesses are wired.
    below is the other wiring from aliexpress that uses the glove box led. i suspect this workaround setup will have the foot well lights stay lit.
  13. Lantaral
    Lantaral Member
    66
    30
    US
    2024 Prius
    In the trims that ship with the footwell lights, do they stay on whenever the car is on, or do they only turn on when the interior lights are on?
    If they're always on, they must be rather dim?
    The LE model doesn't have the harness, would have to run power from the fuse box or another source. Though perhaps the harness could be purchased?
  14. Hammersmith
    1,960
    1,964
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    According to the wiring diagram, the official wires go to two different points (though you can get around that a tiny bit).
    The main connectors are K20 and K21 that both go into the Power Distribution Box Assembly(PDBA) that's sandwiched onto the Main Body ECU in the dash on the far left side(it's right around the drivers dash vent, but down a little bit and deeper toward the firewall).
    K21(18) - left footwell (red)
    K21(19) - right footwell (light blue)
    K20(44) - interior lights(pink) - this line comes from a 5A fuse that controls the dome lights and goes to a junction connector(K116) that services the footwell lights, the red/blue dash LEDs, and the light at the front of the center console(right above the "hidden compartment").
    The correct terminals are:
    K116(7) - left footwell (black)
    K116(8) - right footwell (red)
    So you could either add terminals to K116(7&8), or just tap K20(44) as it comes out of the PDBA.
    The kit from Toyota Japan does it a different way. It includes a switch that you mount in the dash to control the lights manually. From what I can tell, one of the wires goes to a connector not on the USA version of the car, and I haven't figured out what the corresponding connector is yet(if there is one). It adds a terminal to one of the PDBA plugs that's otherwise unused. I think the other end goes to a connector that's meant for optional accessories that are Japan-market only. If you put a gun to my head, I bet it's for a toll road autopay system that can be integrated into the dash.
    At the moment, I think I'm going to custom wire my rear seat footwell lights off the front lights instead of using the included harness with the switch.
    If you'd want to build your own front footwell lights from stock parts:
    82998-24290 - metal terminals to go into K21 and K116 (need 4 total)
    90980-11918 - plastic connectors that go into the LED lights (need 2)
    82998-12690 - metal terminals to go the above connectors (need 4 total)
    81080-33290 - the LEDs themselves (need 2)
    wire to connect the terminals (probably 20AWG because it's easily available, but I bet 22 or 24AWG would be just fine)
    The metal terminals are massively overpriced through Toyota, so searching the part numbers on AliExpress or other sources is probably a better bet.
    If any of you are interested in more info, I can print out the wiring diagrams from TIS and/or scan the Japanese instructions using my printer. But I have to head out now so it will be a bit before I can get to it.
  15. Harters
    Harters Active Member
    335
    426
    UK
    Excel
    In my car (Gen 4) the footwell lights are bright when entering/exiting the car, but as soon as the car is in Ready mode they dim down, but still remain on.
    Lantaral likes this.
  16. Lantaral
    Lantaral Member
    66
    30
    US
    2024 Prius
    Thanks
    Achieving that functionality may require wiring the lights into the same circuit as the dome lights.
  17. Lantaral
    Lantaral Member
    66
    30
    US
    2024 Prius
    For the LE, possibly preferable to install the wiring harness used on the higher trims of the North American vehicles.
    Though perhaps it's not a separate harness.
    #17 Lantaral, Feb 7, 2024
  18. wrtboy168
    70
    27
    2024 Prius
    looks like the aliexpress route is the more practical path. ;)
  19. Lantaral
    Lantaral Member
    66
    30
    US
    2024 Prius
    Certainly the most cost effective, but seems unlikely to offer the same functionality as that of the higher trims.
    Would prefer a high brightness when the dome lights are on (doors are open), then continually dim otherwise.
    #19 Lantaral, Feb 7, 2024
  20. Hammersmith
    1,960
    1,964
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Behavior of stock footwell lights:
    Doors unlocked/opened: 100% brightness
    Car shifted into drive or reverse: <50% brightness
    Car shifted into park: 100% brightness
    Car locked or left shut off for some number of minutes: lights off
    All brightness changes are gradual, not sharp.
    purplePriii, Lantaral and wrtboy168 like this.
